01-21-2008, 23:40 | #63 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: INDONESIA Age: 38
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | Quote:
and CLK from original USB cable, u will get unlock on ur phone... also check this link, i have success few days ago.. http:///vbb/showthread.php?t=489856 br. kevin168 | |
01-24-2008, 08:45 | #67 (permalink) |
Junior Member Join Date: Oct 2007
Member: 610346 Status: Offline Thanks Meter: 2 | How I to the beginning have not never had problems in order then not to succeed piu' to unlock no 6280? On what he depends: not efficient box or cable. E' a question to team BB5. Thanks..... |
01-24-2008, 10:35 | #70 (permalink) |
No Life Poster Join Date: Jan 2005 Location: anywhere there is freedom Age: 47
Member: 106700 Status: Offline Thanks Meter: 47 | unlocking N73 is difficult wiz 3.5, but then again i did not spend time and test it well. i did n73 with ver 3.3 which seems to be doing well. |
01-24-2008, 20:55 | #71 (permalink) | |
Insane Poster Join Date: May 2006
Member: 281005 Status: Offline Thanks Meter: 2 | Quote:
01-25-2008, 01:32 | #72 (permalink) |
Banned Join Date: Oct 2005 Location: www.cilianunlock.com
Member: 194420 Status: Offline Thanks Meter: 15 | Operation: UNLOCK Date: 23-01-2008 Time: 21:24:34 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-181 Version: V_03.70_22-09-06_RM-181_(c)_Nokia. IMEI: 356439012859112 SP LOCK status: Config Key: 7321230140723740 Block 1: CLOSED Type 5 Data: 732123 Block 2: CLOSED Type 5 Data: 74000F Block 3: CLOSED Type 5 Data: 21407F Block 4: CLOSED Type 5 Data: 21402F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70403F Block 7: CLOSED Type 5 Data: 70604F Block 8: CLOSED Type 5 Data: 71030F Block 9: CLOSED Type 5 Data: 71402F Block 10: CLOSED Type 5 Data: 71606F Block 11: CLOSED Type 5 Data: 73002F Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 74807F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_356439012859112_Locked_Keycnt_0_Fbuscnt_0__V_0 3.70_22-09-06_RM-181_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-174_356439012859112_Locked_Keycnt_0_Fbuscnt_0__V_0 3.70_22-09-06_RM-181_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7321230140723740 Block 1: CLOSED Type 5 Data: 732123 Block 2: CLOSED Type 5 Data: 74000F Block 3: CLOSED Type 5 Data: 21407F Block 4: CLOSED Type 5 Data: 21402F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70403F Block 7: CLOSED Type 5 Data: 70604F Block 8: CLOSED Type 5 Data: 71030F Block 9: CLOSED Type 5 Data: 71402F Block 10: CLOSED Type 5 Data: 71606F Block 11: CLOSED Type 5 Data: 73002F Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 74807F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 1000 miliseconds Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7321230140723740 Block 1: OPEN Type 5 Data: 732123 Block 2: OPEN Type 5 Data: 74000F Block 3: OPEN Type 5 Data: 21407F Block 4: OPEN Type 5 Data: 21402F Block 5: OPEN Type 5 Data: 33403F Block 6: OPEN Type 5 Data: 70403F Block 7: OPEN Type 5 Data: 70604F Block 8: OPEN Type 5 Data: 71030F Block 9: OPEN Type 5 Data: 71402F Block 10: OPEN Type 5 Data: 71606F Block 11: OPEN Type 5 Data: 73002F Block 12: OPEN Type 5 Data: 72207F Block 13: OPEN Type 5 Data: 74807F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
01-25-2008, 07:05 | #73 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Melilla, Espaņa
Member: 3389 Status: Offline Sonork: 100.1579083 Thanks Meter: 72 | 2 Nokia 6300 not posible unlock Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.70_24-01-07_RM-217_(c)_Nokia. IMEI: *********XX7457 SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_*********XX7457_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.70_24-01-07_RM-217_(c)_Nokia. IMEI: ************1260 SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Skip autobackup of PM 308 Autobackup file: RM-217_************1260_Locked_Keycnt_0_Fbuscnt_0__V_ 04.70_24-01-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. Please solution |
** BB5BOX Updates Only Here - BB5 v0.0.4.1 - 3/3 10/10 FBUS counter reset ** | MANOLE | BB5BOX | 24 | 03-29-2008 23:30 |
>>> DISCUSSION: Software BB5 Box v0.0.3.4 <<< | RNC_EBM | BB5BOX | 49 | 01-30-2008 13:52 |
>>> DISCUSSION: Software BB5 Box v0.0.3.3 <<< | RNC_EBM | BB5BOX | 56 | 01-19-2008 09:51 |
>>> DISCUSSION: Software BB5 Box v0.0.3.2 <<< | RNC_EBM | BB5BOX | 43 | 01-14-2008 12:05 |
>>> DISCUSSION: Software BB5 Box v0.0.3.1 <<< | RNC_EBM | BB5BOX | 57 | 01-10-2008 21:07 |
