04-22-2008, 16:27 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 272329 Status: Offline Thanks Meter: 13 | E62 can't unlock help Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-88 Version: Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia._ IMEI: 357951005715233 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-88_357951005715233_Locked_Keycnt_1_Fbuscnt_0__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. |
04-22-2008, 18:05 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | See this thread ---> http:///vbb/showth...=489856&page=2 |
04-28-2008, 18:32 | #3 (permalink) |
Member: 272329 Status: Offline Thanks Meter: 13 | |
ETB chip & E62 can't unlock after update | chandy pok | BB5BOX | 0 | 01-18-2008 18:17 |
E62 can't unlock after update v033 | chandy pok | BB5BOX | 0 | 01-16-2008 17:05 |
E62 can't unlock with v030 | chandy pok | BB5BOX | 4 | 01-08-2008 16:38 |
v3i Firmware R479_G_08.B4.34R can't unlock?help sc team | 2ct | Smart-Clip | 7 | 01-09-2007 13:20 |
New Cingular V220 Can't Unlock! Help | davidliu21 | Motorola P2k | 15 | 06-10-2005 17:32 |
