03-03-2009, 08:31 | #1 (permalink) |
Freak Poster Join Date: Aug 2005
Member: 169579 Status: Offline Thanks Meter: 10 | help to unlock nk6300 //phone info log Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. IMEI: 3xxxxxxxxxxxxxxxx SP LOCK status: Config Key: 5050200000000000 Block 1: CLOSED Type 5 Data: 50502F Block 2: CLOSED Type 5 Data: 50502F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! This model/version IS SUPPORTED for UNLOCK //unlock log Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. IMEI: 3xxxxxxxxxxxxxxxx SP LOCK status: Config Key: 5050200000000000 Block 1: CLOSED Type 5 Data: 50502F Block 2: CLOSED Type 5 Data: 50502F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_xxxxxxxxx_Locked_Keycnt_3_Fbuscnt_10__V_06.60_ 21-05-08_RM-217_(c)_Nokia..bin already exist Counter limit reached. Please write PM 308 backup. //reset counterlog Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. IMEI: xxxxxxxxxxxxxxx SP LOCK status: Config Key: 5050200000000000 Block 1: CLOSED Type 5 Data: 50502F Block 2: CLOSED Type 5 Data: 50502F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... //write pm Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. IMEI: 3xxxxxxxxxxxxxxxx Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK //retry unlock Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. IMEI: 3xxxxxxxxxxxxxxx SP LOCK status: Config Key: 5050200000000000 Block 1: CLOSED Type 5 Data: 50502F Block 2: CLOSED Type 5 Data: 50502F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_xxxxxxxxxxxxxxxLocked_Keycnt_3_Fbuscnt_10__V_0 6.60_21-05-08_RM-217_(c)_Nokia..bin already exist Counter limit reached. Please write PM 308 backup. what shall i do next to unlock this 6300 handset pls? |
03-04-2009, 17:32 | #2 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: The Netherlands Antilles Age: 50
Member: 179391 Status: Offline Thanks Meter: 57 | Write PM 308 Quote:
Just write the PM 308, if there is more then 1 in ur folder, choose the first. It should reset counter to 0 from max 10 and 0 from max 3 I have this problem in mines: Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. IMEI: 358647012648818 SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! This model/version IS SUPPORTED for UNLOCK. I have flashed the phone and now it not accepting its locked to simcard and no other simcard | |
Help to unlock Iphone version 3.1.2 (3G phone) | kariakala | iPhone 2 / iPhone 3G / iPhone 3GS | 14 | 03-30-2010 15:07 |
w200i - need help to unlock to any sim... | ThEeDaRkOnE | Phone Unlocking Codes & Maps | 0 | 07-24-2008 12:30 |
help to unlock c55,i will calculate DCT4 code to him | cale | Phone Unlocking Codes & Maps | 2 | 03-01-2003 16:29 |
to all who need help to unlock | komix | x1x to x45/x50 | 0 | 01-22-2002 20:57 |
