12-05-2007, 18:39 | #16 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Chittagong, Bangladesh.
Member: 152752 Status: Offline Sonork: 100.1581661 Thanks Meter: 182 | but this tp is so dificult. make new tp for spansion chips. |
12-06-2007, 03:17 | #18 (permalink) |
Freak Poster Join Date: Feb 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 231588 Status: Offline Thanks Meter: 4 | i have same problem with 5300b, i upgrade it 5.02 version, but it seems its the update 2.08 has the problem, because ever since i unlock 5300 it was successful, but now its a problem for me... pls do something bb5box team. tia |
12-07-2007, 05:46 | #19 (permalink) |
Member: 231588 Status: Offline Thanks Meter: 4 | well its another day for unlocking 5300b.... i figure it out what the h**l is the problem in my box. well first open the cable, check if there is any loose wire that might ground to others.. then uprade again your box. i have now 5300b unlocked phone. but the problem now is the signal! |
12-07-2007, 10:40 | #21 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | thanks for this sir, very useful ............. I just unlock OK as you guided and not kill again cause just push TP one time and done. ------ Operation: UNLOCK Date: 07-12-2007 Time: 13:17:38 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.60_10-02-06_RM-78_(c)_Nokia IMEI: 357603009256074 SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357603009256074_Locked_Keycnt_0_Fbuscnt_0__V_03 .60_10-02-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_357603009256074_Locked_Keycnt_0_Fbuscnt_0__V_03 .60_10-02-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2620100000000000 Block 1: OPEN Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
12-07-2007, 14:59 | #23 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Brazil Age: 49
Member: 229576 Status: Offline Thanks Meter: 9 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.26_16-03-07_RM-198_(c)_Nokia. IMEI: 3532320120XXXXX SP LOCK status: Config Key: 7240500000000000 Block 1: CLOSED Type 5 Data: 72405F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-198_3532320120XXXXX_Locked_Keycnt_0_Fbuscnt_0__V_0 4.26_16-03-07_RM-198_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-198_3532320120XXXXX_Locked_Keycnt_0_Fbuscnt_0__V_0 4.26_16-03-07_RM-198_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7240500000000000 Block 1: CLOSED Type 5 Data: 72405F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7240500000000000 Block 1: OPEN Type 5 Data: 72405F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
12-07-2007, 17:24 | #24 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Tunisia Age: 53
Member: 240499 Status: Offline Thanks Meter: 151 | ------ Operation: UNLOCK Date: 07-12-2007 Time: 10:26:56 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353949016xxxxxx SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_353949016xxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_353949016xxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2081000000000000 Block 1: OPEN Type 5 Data: 20810F Block 2: OPEN Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
12-12-2007, 18:04 | #26 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | same problem with 5200 its easy tp, but after having error 55 mobile is dead very strang bb5box team, please review ur soft till now, i lost more than i gain with this box is it the same with the same other boxes |
12-13-2007, 19:43 | #28 (permalink) | |
Freak Poster Join Date: Sep 2004 Age: 46
Member: 83654 Status: Offline Thanks Meter: 4 | Quote:
I try one pieces of 5200 too and now is dead phone. Same problem. Any ideea for repairing this phone??? Is urgent.... | |
12-14-2007, 17:00 | #29 (permalink) | |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | 5200 unlock problem Quote:
connect red wire to + of phone connect black wire to - of phone connect dku cable connect rj45 to box click read phone and 308 area pres unlock connect gnd connect clk and data test point connected ok tries from 1 to 10 please try again and voila phone is dead its atb 5200 | |
very important info for all blutooth enabled headset users | samj | Nokia Multimedia | 10 | 07-21-2006 09:58 |
Important Info For All Gsm Site Owners And Users | GSM Solutions Ireland | Nokia Multimedia | 7 | 03-16-2003 01:50 |
Important Info For All Gsm Site Owners And Users | GSM Solutions Ireland | GSM Mobile Links | 0 | 03-14-2003 17:40 |
Importent Info for DCT 4 Unlockcodes | jan | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 02-09-2003 23:38 |
Important info for flashing with Laptop | GSM Coolhawk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-29-2002 00:36 |
