12-16-2007, 13:05 | #16 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | the phone gives error with bb5box done my MT with my very own hands on 1st try . |
12-16-2007, 13:10 | #17 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.81_09-05-06_RM-78_(c)_Nokia IMEI: 35xxxx9796580 SP LOCK status: Config Key: 2720500015194980 Block 1: CLOSED Type 5 Data: 27205F Block 2: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_35xxxx19796580_Locked_Keycnt_0_Fbuscnt_0__V_03. 81_09-05-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_35xxxxxxxx9796580_Locked_Keycnt_0_Fbuscnt_0__V_ 03.81_09-05-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2720500015194980 Block 1: CLOSED Type 5 Data: 27205F Block 2: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2720500015194980 Block 1: OPEN Type 5 Data: 27205F Block 2: OPEN Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull 6280 spansion BR khemal |
12-16-2007, 13:18 | #19 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Spansion is not problems for me always 100% but some SEC ETA always stuck ... & 2 phones out of 10 E65 always stucks says unlocking failed ..... |
12-16-2007, 14:17 | #20 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
We will try to put an schematic of cables. Until that, you can try some other GND locations or much better try to change wires for CLK and DATA of your cables. Also hope you not modify the length of your cable ... | |
12-16-2007, 15:55 | #21 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | Thanks BB5 good answered!!! After update firmware & software realy get problem.But after I modify the GND & CLICK cable again it's realy working fine.So BB5 supporter that's Ur correct answered.Pls don't make Ur user get problem.Thanks. |
12-16-2007, 16:19 | #22 (permalink) | |
http://forum.gsmhosting.com/vbb/showthread.php?t=475632 For that reason we made that thread sticky. | |
12-16-2007, 16:35 | #23 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | unlock 5200 without pb with v29, killed 5200 with v28, making the same procedure think bugs r fixed in new ver that's true, changed gnd and goes on first try after three tries failed |
12-18-2007, 09:44 | #24 (permalink) |
Freak Poster Join Date: Mar 2007 Location: africa
Member: 461554 Status: Offline Thanks Meter: 55 | Operation: UNLOCK Date: 18-12-2007 Time: 08:54:27 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 351861018122093 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_351861018122093_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343000000000000 Block 1: OPEN Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
12-18-2007, 13:00 | #26 (permalink) |
Insane Poster Join Date: May 2003 Location: Troisdorf, Germany Age: 41
Member: 29086 Status: Offline Thanks Meter: 5 | After Update to 2.8-2.9 ican Nothing Unlocking this error Massage Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.91_25-09-06_RM-145_(c)_Nokia IMEI: 354821010614908 SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-145_354821010614908_Locked_Keycnt_0_Fbuscnt_0__V_0 4.91_25-09-06_RM-145_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-145_354821010614908_Locked_Keycnt_0_Fbuscnt_0__V_0 4.91_25-09-06_RM-145_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. Waht its the problem yet? |
