11-14-2007, 20:14 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: barsoume
Member: 515559 Status: Offline Sonork: no Thanks Meter: 121 | nokia 6300 and nokia 6131 unlock succefuly Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 359390007501226 SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 1 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-115_359390007501226_Locked_Keycnt_3_Fbuscnt_1__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-115_359390007501226_Locked_Keycnt_3_Fbuscnt_1__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 1 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2080100000000000 Block 1: OPEN Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull nokia 6300............ earching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 358648018068753 SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_358648018068753_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_358648018068753_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2080100000000000 Block 1: OPEN Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
how to unlock nokia 6300 and n95 8gb | irfan_gsm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-24-2010 14:18 |
6300 and 6280 can't unlock anymore | GSMaxx | J.A.F. V-SPEC | 2 | 11-03-2008 14:54 |
nokia 6300 b how to unlock with jaf | PATELKETAN | Nokia Hardware & Hardware Repair | 0 | 01-05-2008 11:11 |
6300 and 5200 not unlock without log | sarbi | MT-BOX | 2 | 09-14-2007 12:35 |
