03-19-2008, 11:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Comilla Age: 42
Member: 304260 Status: Offline Sonork: 100.1593127 Thanks Meter: 355 | Nokia 6300 RM-217 V_05.50_14-08-07 Help At first phone come with 04.20 version then upgrade to 05.50 version but same result. Please Help. ------ Operation: READ PHONE INFO Date: 19-03-2008 Time: 15:15:49 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.20_05-12-06_RM-217_(c)_Nokia. IMEI: 359810011703153 SP LOCK status: Config Key: 2720200000000000 Block 1: CLOSED Type 5 Data: 27202F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! ------ Operation: READ PHONE INFO Date: 19-03-2008 Time: 15:47:03 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359810011703153 SP LOCK status: Config Key: 2720200000000000 Block 1: CLOSED Type 5 Data: 27202F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! ------ Operation: UNLOCK V1 Date: 19-03-2008 Time: 15:47:10 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359810011703153 SP LOCK status: Config Key: 2720200000000000 Block 1: CLOSED Type 5 Data: 27202F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_359810011703153_Locked_Keycnt_3_Fbuscnt_10__V_ 05.50_14-08-07_RM-217_(c)_Nokia..bin Counter limit reached. Please write PM 308 backup. ------ Operation: UNLOCK V2 Date: 19-03-2008 Time: 15:47:30 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359810011703153 SP LOCK status: Config Key: 2720200000000000 Block 1: CLOSED Type 5 Data: 27202F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_359810011703153_Locked_Keycnt_3_Fbuscnt_10__V_ 05.50_14-08-07_RM-217_(c)_Nokia..bin already exist Counter limit reached. Please write PM 308 backup. ------ Operation: WRITE PM 308 Date: 19-03-2008 Time: 15:47:38 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359810011703153 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Not selected any file, exit procedure |
03-19-2008, 11:05 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Always Here Age: 37
Member: 333494 Status: Offline Sonork: 100.1607053 Thanks Meter: 190 | Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Not selected any file, exit procedur you have bckp. ??? |
Nokia 6300 RM-217 dead USB flash problem need help | ar_memon2 | Nokia Base Band 5 ( BB-5 ) | 9 | 07-25-2011 11:19 |
Nokia 6300 RM-217 ver 07.30 | @NAYEM121 | Nokia Base Band 5 ( BB-5 ) | 0 | 02-26-2010 13:10 |
Urgent Need Help Team Plz Nokia 6300 RM-217 Signal Problem | blast.gsmhost | Nokia Hardware & Hardware Repair | 0 | 02-15-2010 08:28 |
firmware nokia 6300 RM-217 DP20 8.20 sw-07.21 | maciej2k | Nokia Base Band 5 ( BB-5 ) | 0 | 02-07-2009 18:17 |
nokia 6300 rm 217 after flash just nokia show then white screen | shani72 | Nokia Hardware & Hardware Repair | 7 | 11-22-2008 05:57 |
