09-21-2007, 12:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 17424 Status: Offline Thanks Meter: 15 | Problem unlocking N73 I am having problem unlocking N73, I have had 5 goes unlocking but still unlock fails. Don't want to continue for a long time as the test points are very easy to damage. any ides please Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 353640017853777 SP LOCK status: Block 1: CLOSED Type 5 Data: 23415F Block 2: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Skip autobackup of PM 308 Autobackup file: RM-133_353640017853777_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin already existe Please connect testpoints Testpoints connected OK ... Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. br msa |
09-21-2007, 13:01 | #3 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Hi Thanks for the reply, Does the test points have to be connect all the time while unlocking ?. I disconnect them after it says test point OK. br msa PS Tried with test point connect all the time 3 more times still same problem. br msa Last edited by msa; 09-21-2007 at 13:07. |
09-21-2007, 13:07 | #4 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
You should keep testpoints connected on unlock procedure. From this message: Testpoints connected OK ... until software finish unlock procedure. It is not long time, 1-2 seconds! Again, PLEASE READ USER MANUAL before start anything | |
09-21-2007, 15:51 | #5 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Hi Thanks for the reply, i have read the manual now , I get this error now. Just to clarify is N73 music Edition supported by the software, If not then please accept my apologies for trying . Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 353640017853777 SP LOCK status: Block 1: CLOSED Type 5 Data: 23415F Block 2: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Skip autobackup of PM 308 Autobackup file: RM-133_353640017853777_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin already existe Please connect testpoints Testpoints connected OK ... Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... ERROR: 11160001 ERROR: 30020052 Now on the GOOD side, I have managed to unlock 6300 without any problems . br msa |
09-21-2007, 16:05 | #6 (permalink) | ||
Product Manager Join Date: Jan 2006 Location: 亚洲 / Asia Age: 36
Member: 222198 Status: Offline Sonork: 100.102981 Thanks Meter: 3,813 | Quote:
B.R., Viru | ||
09-21-2007, 16:57 | #8 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | N73 work well on our side, no matters Music Edition or not, firmware is same inside flash chip. Also we have inside our phones exactly the flash chip from attachament photo. Here is our log result with N73 on same flash version that you have: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 3536400xxxxxxxx SP LOCK status: Block 1: CLOSED Type 5 Data: 26003F Block 2: CLOSED Type 5 Data: 26003F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-133_3536400xxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin Please connect testpoints Testpoints connected OK ... Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 26003F Block 2: OPEN Type 5 Data: 26003F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull So, please try this: 1. Try with GND connected in another point. Look attachament, I marked exactly point where is conected GND in our test phones. You can also try to solder some small wire (1-2 cm long) for GND, and attach crocodile climp to this small wire. 2. If you still get same error, remove testpoints, do NOT disconnect phone from power (I mean Vbat+, BSI, GND and DKU2-FBUS), press again Unlock button, and connect testpoints when software ask for that. Check also if DKU-2 bottom connector pins are dirty, try to clean it. 3. Try to upgrade to V_05wk47v46.3_04-06-07_RM-133_(c)_Nokia. (you can use this datapackage file: RM-133_APAC_4.0723.2.0.1_v7.0.exe ) |
09-21-2007, 19:20 | #9 (permalink) | |
Member: 17424 Status: Offline Thanks Meter: 15 | Quote:
Thanks very much for your detailed help. but I still seems to be unable to unlock. I have upgraded the phone to V_05wk47v46.3_04-06-07_RM-133_(c)_Nokia from support site, when I start the unlock process it give me these errors as stated in previous post. ERROR: 11160001 ERROR: 30020052 If I start the process agian as you explained in your post without disconnecting anything then I get this error Searching for phone ... ERROR: Cannot detect phone on FBUS interface It looks like the phone is swithing off automatically, I have to the power the phone on agian to start the unlock process again. Any idea why the phone is getting switched off? Thanks for been paitent. br msa | |
09-21-2007, 19:46 | #10 (permalink) |
No Life Poster Join Date: Jan 2006 Location: gsm market Age: 35
Member: 222481 Status: Offline Thanks Meter: 30 | well long time ago , i had same problem wiz mt-pro. well it goes to test or local mode , and off after 30sec rite? it is cable problem . wen you power all ok but after sometimes it loses contact and off the phone try to clean your cable connector it must be same problem br ryaz |
09-21-2007, 20:06 | #11 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Hi Thanks for your help. The phone does not switch off until it reaches this stage, Please connect testpoints Testpoints connected OK ... Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... ERROR: 11160001 ERROR: 30020052 before that phone can be on for a long time without swiching off. I have done every thing to clean contacts but not getting any where, but I shell keep trying br msa |
09-21-2007, 20:30 | #12 (permalink) | |
Member: 222481 Status: Offline Thanks Meter: 30 | Quote:
if only displaying nokia there maybe a security code or automatic keypad lock active br ryaz br ryaz | |
09-22-2007, 09:30 | #14 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | I made some tests, and ryaz1993 had right. Changed Security code and activated Autolock, get same error. Here we made update who make Full factory defaults before start unlocking: http://www.bb5box.org/Downloads/BB5_v019.zip Please use this, and report your results. |
09-22-2007, 12:23 | #15 (permalink) | |
Thanks for the file, Inside zip file the version is still v018, is it correct? or should it be v019? I will try this anyway. br msa | |
Problem unlocking N73 | Joxter8 | BB5BOX | 11 | 03-26-2008 19:53 |
Problem unlocking n73, e65 | kamilmaly2004 | MT-BOX | 20 | 01-14-2008 06:59 |
problem unlocking N73 and 6131. | djouaka | BB5 Box by D.K. | 4 | 12-20-2007 10:52 |
Problems unlock N73 bb5box | ultracell2 | BB5BOX | 3 | 10-29-2007 21:53 |
problem unlocking N73 | shaheen15 | MT-BOX | 2 | 08-24-2007 19:20 |
