02-21-2008, 00:55 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | Raskal I need your HELP !!! PLEASE !!! Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353227010427104 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353227010427104 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_353227010427104_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 |
02-21-2008, 00:59 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | U made something wrong maybe wrong TP damaged RAP chip if u can take a pic from TP are and uplead will be usefull to help u BR, Tito Millo |
02-21-2008, 01:25 | #5 (permalink) |
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Seems like 2 pins are both but cant see clearly other way ur fone is dead could be that u made contact with any diode accidentally and that made overvoltage in ur fone and shut it off...also try leaving it away for some hours i had same problem with N73 and after a day i flashed and turn on all ok...try this option BR, Tito Millo |
02-21-2008, 01:36 | #6 (permalink) | |
Member: 614304 Status: Offline Thanks Meter: 150 | Quote:
11-05-2009, 23:58 | #8 (permalink) |
Junior Member Join Date: Apr 2008
Member: 747542 Status: Offline Sonork: ilhanrnm Thanks Meter: 2 | Hi Everbody i need urs help. I have N 73 and when i turn on it with sim card it being closed. but when i turn on without sim card everything is normal but when i call EMERGENCY CALL (without sim) it being closed again. i cant open it with sim card so when coming network is being shut down... |
Need Your Help Please-Sagem myX-2 code. | scientist | Phone Unlocking Codes & Maps | 2 | 04-27-2004 10:26 |
I need your help please | alibadr33 | Siemens-Benq RingTones and WallPapers | 0 | 12-09-2003 14:41 |
i need your help,please | xervas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-2000 15:27 |
