12-26-2008, 15:41 | #32 (permalink) | |
Banned Join Date: Jul 2005 Location: P.R.China Age: 40
Member: 162387 Status: Offline Sonork: 100.86669 Thanks Meter: 457 | Quote:
IMPOSSIBLE !!! Give me your account user name and i am looking on the server for any possible error and will tell you after i check what is the matter. Best Wishes, Susan www.gsm-traders.com | |
12-26-2008, 15:48 | #33 (permalink) | |
what is your user name in server, so i can check the data. You saying the password calculated by dejan card was not correct even u was update the phone to generic firmaware. Question: Have you try the after flashing the phone to use the calculated password to enter via JAF? Question: Why have u lost 2 credits, u said you have 1 phone. Post here the last 4 digits from phone's imei nr. Also post here the user name for your account. Best Wishes, Susan www.gsm-traders.com | |
12-26-2008, 18:14 | #34 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Spain Age: 41
Member: 113587 Status: Offline Thanks Meter: 16 | Quote:
12-26-2008, 19:28 | #35 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
Well i have backup in server for all unlock data, but also if you are using DK card than u have the calculated password inside the key folder, except you delete it. If you connect SAME PHONE WITH SAME IMEI, than you can do it this operation 1000 times and nothing will happens since it is recognized as UNLOCKED from Dejan's soft. But if you delete this data, sure you loose one more credit for same phone. Since after reflasing the phone with generic software, you could simple insert code via jaf or if you press unlock button again on dejan soft it will take the saved data (password) and write it into phone, also. So i can affirm, if is used how it should be, you can't loose any credit. B.R., Raskal | |
unable to unlock this phone.Password is not correct | usaflex | BB5 Box by D.K. | 13 | 03-17-2009 23:40 |
Unable to unlock this phone... | gsmcenter_pl | BB5 Box by D.K. | 4 | 01-11-2009 16:51 |
Error: Unable to unlock this phone. Password is not correct ! | Nokiasimer | Nokia Base Band 5 ( BB-5 ) | 9 | 08-06-2008 23:51 |
Unable To Unlock This 02 Xda2 !!! | albarka network | HTC & PDA WM( With Touchscreen) | 1 | 10-13-2007 15:46 |
