02-10-2008, 15:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | 6085 unlock problem 6085 soft 5.03 new flash. unlock phone only after about 5 -6 tries using latest build of jaf Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-198_356417014057786_05.03_LCK_backup.pm Restarting phone... Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 4250200000000000 Provider: Celcomm;Israel Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 42502F Reading phone...Type: RM-198, Ver: 05.03 Reading imei... Imei: 356417014057786 Reading HW ID...1403 Found general data... Waiting for TP confirmation.............Sending code... Error unlocking! Code: 08 Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-198_356417014057786_05.03_LCK_backup.pm Restarting phone... Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 4250200000000000 Provider: Celcomm;Israel Key Code count: 1, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 42502F Reading phone...Type: RM-198, Ver: 05.03 Reading imei... Imei: 356417014057786 Reading HW ID...1403 Found general data... Waiting for TP confirmation.............Sending code... Error unlocking! Code: FFFFFFF and so on ... unlock o.k after few tries. why this happen ? also , what is the batton on data for ? it doesnt metter if i press or no , same results , as soon as i touch data point unlock starts why ? |
02-11-2008, 19:37 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | you dont need to press any button. a raskal posted, the cables are from dejan box, but on jaf plus, there is no need to press the button from data needle. |
02-13-2008, 13:43 | #4 (permalink) |
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | if you will lookn carefully, all new pcbs from 5200, 5300, 6300, 3110, 3109 and so on, have something on the pcb, like a paint (i dont know now the english word) if you will scratch with an cutter over 2 testpoints, you will be able to unlock those models from first try. br |
6085 unlock problem | Selmir | Nokia Base Band 5 ( BB-5 ) | 4 | 10-02-2008 08:34 |
Nokia 6085 unlocking problem | elgar | J.A.F. V-SPEC | 5 | 04-10-2008 16:54 |
6085 unlock problem help GT | sairat | MT-BOX | 2 | 01-29-2008 05:33 |
6085 unlock problem | rajabrotherscom | MT-BOX | 4 | 01-20-2008 21:45 |
6085 unlocking problem | alfox | BB5BOX | 1 | 10-25-2007 05:31 |
