04-13-2008, 00:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 39
Member: 138583 Status: Offline Thanks Meter: 120 | Do I can flash via JAF Plus? Im tryng to unlock a 5200 telcel, but I see this: Getting MCU ID MCU ID: 0x0000 Can't find boot file... Failed! Aborting! Done! Phone Restarted... Powering the phone... Failed! Aborting! Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04.72 26-03-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: pb06w14v33 PPM version: V 04.72 26-03-07 RM-174 (c) Nokia. L Retu version: 32 Tahvo version: 53 Content Pack version: Content: l V 04.72 26-03-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 06 F7 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... C:\Archivos de programa\ODEON\JAF\ProgData\RM-174_356439010015063_04.72_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Reading phone...Type: RM-174, Ver: 04.72 Reading imei... Imei: 356439010015063 Reading HW ID...3000 Version Not supported! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04.72 26-03-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: pb06w14v33 PPM version: V 04.72 26-03-07 RM-174 (c) Nokia. L BT MCM version: 06cc-P8.0 Retu version: 32 Tahvo version: 53 Content Pack version: Content: l V 04.72 26-03-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 06 F7 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Wanna know if I can flash it instantly for have on it a version compatible for unlock.... Without disconnect it from JAF Plus.... Thanks |
04-13-2008, 09:34 | #2 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Hey, firstly solve the problem you did, then read on your box if you JAF Plus it's Mexico edition or not. Regarding flashing, check if the version that you have it's supported before flashing(If you firstly have JAF PLUS MEXICO EDITION). Then we can talk about flashing. You must use JAF alone without plus connected BR Luskao |
6700c Change Language Succesfully Flashed via JAF | d'odders | Nokia Base Band 5 ( BB-5 ) | 14 | 07-23-2010 17:25 |
Can I use JAF Plus as interface?? | -luigi- | BB5KING | 0 | 11-25-2008 05:36 |
how can i buy jaf plus | abdooo_19888 | J.A.F. Plus | 6 | 01-30-2008 19:08 |
Please Help me which BB5 Box i can buy between JAF PLUS-BB5BOX-MT-PRO LITE. | Unlocker_001 | Nokia Base Band 5 ( BB-5 ) | 6 | 12-27-2007 19:02 |
