06-10-2008, 17:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | jaf setup .51 cant unlock same n95 setup 50 unlock finely i have managed to unlock n95 with less problems. i have tested latest bulid 51 on this n95. jaf will not send any code or detect any tp for n95 (6085 unlocked first try) i have tested about 20 times for this phone , i then opened .50 build , and same N95 same cable same conection to the phone unlocked first try. please fix this bug as in latest builds bb5 unlock is working o.k |
06-10-2008, 18:10 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: In front of my computer
Member: 71180 Status: Offline Thanks Meter: 811 | TP detection has nothing to do with software. Should be a coincidence that worked in .50. If tp is not detected then needels don't make contact. N95 have small layer of glue over tp, scratch a little before TP JAF |
06-10-2008, 18:16 | #3 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
runing jaf 50 , doing same witout even disconecting phone , same cables and all. and unlock first try with 50 .... on older setup i couldnt unlock any n95 only after many tries. | |
07-01-2008, 22:03 | #4 (permalink) | |
i have tested over the week about 10 units of N95 ..... first tested on setup 51 ..... only 3 of the phones got unlocked with SETUP 51 .... all others only unlocked with setup 50 ..... on setup 51 jaf keep beeping on tp detection , some times i wait long time then i get like 10 times in a raw error about code or something and after reading phne i got 3/10 tries on code..... on other tries it just keep beeping on detection tp ..... and keep going. on setup 50 you get tp on phone , wait few secs then its sending code and phone unlocked first try ..... i hope it will be fixed ...... even if you say it cant be ..... all used same cable , and not even removing box from usb , just closing 51 and open 50 ..... with 51 np unlocked 6280 first try , 6085 ,6086 , 6086b ..... and others ... for N95 very anoying problem please see if you can fix it ... also maybe update suported versions for latest .... | |
07-01-2008, 22:11 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Location: SBZ-TUNISIA Age: 54
Member: 104036 Status: Offline Thanks Meter: 44 | i confirm same problem i get with ver 51 and 6280 (have done before in vers 47 ) but with last version 51 sometimes it freeze and must restart all in some times no responce even with tp connected ??????? i havent test with vers 50 .... i will test and confirm .......... |
07-02-2008, 16:37 | #7 (permalink) | |
Member: 104036 Status: Offline Thanks Meter: 44 | Quote:
after try with vers 50 the same phone unlocked in first try !!!!!!!!!!!!!!!!!! Code: JAF version 1.98.51 Detected PKEY: 900TATOU Card life counter: 99.99% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.43 30-03-07 RM-78 (c) Nokia HW version: 2005 PCI version: RFIC version: 17211721 DSP version: pb05w46v49 LCD version: SEIKO PPM version: V 06.43 30-03-07 RM-78 (c) Nokia C Retu version: 32 Tahvo version: 52 Production serial number: CSB814057 Product code: 0536009 Module code: Basic production code: 0520041 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 351900012048522 IMEI spare to net: 3A 15 09 00 21 40 58 02 IMEI SV to net: 33 15 09 00 21 40 58 12 F8 LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2081000000000000 Provider: SFR;France Key Code count: 2, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 20810F Block 2: Lock 1: CLOSED -> Lock Data: 64710F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-78.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0536009 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Fichiers communs\Nokia\DataPackage\Products\RM-78\rm7830006.430.mcusw PPM Flash file: C:\Program Files\Fichiers communs\Nokia\DataPackage\Products\RM-78\rm783006.43.ppm_c CNT Flash file: C:\Program Files\Fichiers communs\Nokia\DataPackage\Products\RM-78\rm7830006.43.image_c APE Variant file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkish,Portuguese Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2081000000000000 Provider: SFR;France Key Code count: 2, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 20810F Block 2: Lock 1: CLOSED -> Lock Data: 64710F Reading phone...Type: RM-78, Ver: 06.43 Reading imei... Imei: 351900012048522 Reading HW ID...2005 Found general data... Waiting for TP confirmation......................................................................................................................................................................Sending code... Sending code... Sending code... Unlock OK! Switching to serial... Powering the phone... Reading... MCU SW version: V 06.43 30-03-07 RM-78 (c) Nokia HW version: 2005 PCI version: RFIC version: 17211721 DSP version: pb05w46v49 LCD version: SEIKO PPM version: V 06.43 30-03-07 RM-78 (c) Nokia C Retu version: 32 Tahvo version: 52 Production serial number: CSB814057 Product code: 0536009 Module code: Basic production code: 0520041 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 351900012048522 IMEI spare to net: 3A 15 09 00 21 40 58 02 IMEI SV to net: 33 15 09 00 21 40 58 12 F8 LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2081000000000000 Provider: SFR;France Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-78.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0536009 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Fichiers communs\Nokia\DataPackage\Products\RM-78\rm7830006.430.mcusw PPM Flash file: C:\Program Files\Fichiers communs\Nokia\DataPackage\Products\RM-78\rm783006.43.ppm_c CNT Flash file: C:\Program Files\Fichiers communs\Nokia\DataPackage\Products\RM-78\rm7830006.43.image_c APE Variant file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkish,Portuguese Done! | |
07-03-2008, 09:10 | #8 (permalink) |
No Life Poster Join Date: Aug 2003 Location: portugal
Member: 37485 Status: Offline Thanks Meter: 77 | i have been trying for several days on 2 N95 and still couldn´t unlock it... with this new version 51. but in other models it worked at first 5200-5300-6288-6280-6233-6234-N73 i will try later the N95 with older 50 version and post results. PS: yes the test point are ok and clean. |
jaf setup 51 | omary | J.A.F. Plus | 1 | 06-18-2008 11:26 |
As unlock db2020 cid 49/50/51 with UB? | Tamper | Universalbox | 2 | 04-16-2008 09:57 |
cant unlock same log on 3 units... | sygnal | SMTi | 5 | 07-31-2007 05:54 |
