01-09-2008, 22:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: GB Age: 54
Member: 24791 Status: Offline Thanks Meter: 35 | All tries have been used restoring simlockdata pls see log below FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.00 27-04-07 RM-209 (c) Nokia. HW version: 1001 PCI version: RFIC version: 17211721 DSP version: pb06w14v51 PPM version: V 05.00 27-04-07 RM-209 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 52 Content Pack version: Content: c_uk V 05.00 27-04-07 RM-209 (c) Nokia. Production serial number: CEG936905 Product code: 0535819 Module code: 0203099 Basic production code: 0534038 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 353240011058372 IMEI spare to net: 3A 35 42 00 11 50 38 07 IMEI SV to net: 33 35 42 00 11 50 38 07 F8 LOCK STATUS: CONFIG KEY: 2340000300000000 Provider: Tesco Mobile (3510i);United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23410F Lock 2: CLOSED -> Lock Data: 23410F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-209.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0535819 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-209\rm209__05.00.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-209\rm209__05.00.ppm_c CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-209\rm209__05.00.image_c_uk APE Variant file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2340000300000000 Provider: Tesco Mobile (3510i);United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23410F Lock 2: CLOSED -> Lock Data: 23410F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2340000300000000 Provider: Tesco Mobile (3510i);United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23410F Lock 2: CLOSED -> Lock Data: 23410F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restarting phone... Done! Detecting phone... failed! |
01-10-2008, 00:00 | #2 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 30661 Status: Offline Thanks Meter: 0 | Try pressing power on the phone... Then do an INF, if it reads ok, click Restore Backup (or something similar to that, under Unlock stuff) then click Unlock... That should reset the counter to the last backup... It should do a backup automatically before the unlocking if you have switched PC's then check Progdata directory on the first PC you used to try and unlock this phone... Once the backup is restored try again |
01-15-2008, 22:53 | #4 (permalink) |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | you have all counters blocked: CONFIG KEY: 2340000300000000 Provider: Tesco Mobile (3510i);United Kingdom Key Code count: 3, FBUS Code count: 10 first of all, you must make rpl for this phone, after that try to unlock. maybe someone played with it before you and he blocked the counters. br |
01-16-2008, 01:01 | #5 (permalink) | |
Member: 24791 Status: Offline Thanks Meter: 35 | Quote:
07-15-2008, 20:34 | #7 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: albania
Member: 133415 Status: Offline Thanks Meter: 46 | Quote:
CONFIG KEY: 8000000000000000 PROVIDER KEY: 2340000100000000 Provider: Virgin - SPECIAL CODE;United Kingdom Key Code count: 3, FBUS Code count: 10 | |
07-15-2008, 21:43 | #8 (permalink) | |
07-20-2008, 18:14 | #9 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | Man, well you need to understand one thing, if the phone that you get was already 3 / 10 i.e : Key Code count: 3, FBUS Code count: 10, then you must read ASK to make RPL and then it will return back the phone to: Key Code count: 0, FBUS Code count: 0 Now if the phone was already Key Code count: 0, FBUS Code count: 0, then by trying to unlock with JAF it uses all the tries and tell you all tries USED, then JAF has already keep a BACKUP of the PM, you just need to RESTORE BACKUP, it is LOCATED in the LOCK setting where you have options to choose 1. Unlock by codes, 2. Unlock by TP, etc... you choose RESTORE BACK UP, and then you PRESS unlock... Jaf shall restore your PHONE to Key Code count: 0, FBUS Code count: 0. Hope you UNDERSTAND !!! |
07-27-2008, 20:41 | #10 (permalink) | |
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | Quote:
before posting, please try to see the date of the thread: 9th Jan 2008 23:59 since version 53, jaf sw have an option for counter reset. you can use it closed | |
6300 All tries have been used.. | valiu | J.A.F. Plus | 1 | 10-03-2008 18:38 |
u880, need to unlock, but all files have been deleted | kizzyq | LG | 0 | 04-02-2008 15:05 |
All tries have been used.. restoring simlockdata! | Casmos | J.A.F. V-SPEC | 1 | 02-14-2008 17:03 |
All tries have been used.. again and again and again | hawks007 | J.A.F. V-SPEC | 6 | 02-01-2008 15:08 |
All algorithms have been checked. No compatible found ! | ACE_UK | Federal One | 10 | 11-22-2003 18:04 |
