07-08-2008, 13:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 39
Member: 138583 Status: Offline Thanks Meter: 120 | Why always error??? Im becoming crazy tryng 2 unlock 5200 TelCel Detected PKEY: 90005C8B Card life counter: 77.86% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112 JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Archivos de programa\ODEON\JAF\ProgData\356439010015063_CRT_ba ckup_143187.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Read SP data error! or Phone not supported FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Reading phone...Type: RM-174, Ver: 05.51 Reading imei... Imei: 356439010015063 Reading HW ID...3000 Found general data... Waiting for TP confirmation...................................... ....................Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Error unlocking! Code: 02 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Reading phone...Type: RM-174, Ver: 05.51 Reading imei... Imei: 356439010015063 Reading HW ID...3000 Found general data... Waiting for TP confirmation...................................... ...Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Error unlocking! Code: 07 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Reading phone...Type: RM-174, Ver: 05.51 Reading imei... Imei: 356439010015063 Reading HW ID...3000 Found general data... Waiting for TP confirmation...................................... .......................Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Error unlocking! Code: 07 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Reading phone...Type: RM-174, Ver: 05.51 Reading imei... Imei: 356439010015063 Reading HW ID...3000 Found general data... Waiting for TP confirmation...................................... ......Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Error unlocking! Code: 07 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.51 05-09-07 RM-174 (c) Nokia. HW version: 3000 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.51 05-09-07 RM-174 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 05.51 05-09-07 RM-174 (c) Nokia. Production serial number: RGI346391 Product code: 0542059 Module code: 0203054 Basic production code: 0530543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356439010015063 IMEI spare to net: 3A 65 34 09 01 10 05 06 IMEI SV to net: 33 65 34 09 01 10 05 16 F3 LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-174.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0542059 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 334020 Block 2: Lock 1: CLOSED -> Lock Data: 334020 Reading phone...Type: RM-174, Ver: 05.51 Reading imei... Imei: 356439010015063 Reading HW ID...3000 Found general data... Waiting for TP confirmation...................................... ............Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Error unlocking! Code: 07 My Box is JAF Plus telcel edition.... |
07-08-2008, 22:05 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Location: portugal
Member: 37485 Status: Offline Thanks Meter: 77 | CONFIG KEY: 3000000000000000 PROVIDER KEY: 3340201549764300 Provider: Unknown provider-----------------this is your problem rewrite RPL backup and check provider then unlock |
CF62T error tryng 2 unlock.... | -luigi- | DreamBox | 3 | 06-24-2009 09:16 |
[help] no unlock 5200 telcel :( | WeBoXGT | NoooX Box | 5 | 09-23-2008 23:26 |
Cant unlock 5200 TelCel | -luigi- | J.A.F. Plus | 5 | 04-15-2008 08:17 |
why always error when flashing 6020,3220 | CONG YANG | MT-BOX | 2 | 08-25-2007 09:25 |
why...why....why....always error in update. | j2000 | Phoenix Black Box | 2 | 06-18-2005 21:52 |
