Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 06-11-2008, 06:56   #1 (permalink)
Member: 478839
Thumbs down big problem with spiderman
dear jack sir,
i have problem with spiderman 68047300 error on onboard usb port
but in pci usb box is connected using version v 2.40 but when i connect mobile & then cable for battery connector red to +ve & black -ve box beep & disconnected(searchasing rx tx on box) i have connected 4 to 5 mobile but problem is same then show error 68047300 big problem sending to spiderman but when i try with mobile battery it search rx tx cable but with using battery i can't format flash please give me soulation or give me advise to purchase new box
i have update it it shows v 2.30 before it was v 2.18 i already posted 2 thread before .
thanks please give me solution...............................
Old 06-11-2008, 07:21   #2 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 219
reinstall box driver may solve your problem
Old 06-11-2008, 10:28   #3 (permalink)
Member: 637177
Sonork: 100.103098
Thanks Meter: 8,663
if the power cable red connect to back or Conductor connecting through other,box will give you beep,so you need check phone connect is good
check use this for connect phone,see the photo
Old 06-11-2008, 19:31   #4 (permalink)
Member: 478839
Thumbs down
i did that with this connect cable with mobile spiderman losting driver when i unplug & plug it again with not connect cable spider dected by comp ok show all info. but with battery it search phone rx tx but i cant format mobile with battery because mobile started
i can sand my box u sir u chack it may be technical fault.
for better support...
Old 06-14-2008, 07:34   #5 (permalink)
SE-THAILAND's Avatar
Member: 10084
Thanks Meter: 283
sure u cant do with battery.cause GND from box not connect to phone.why u need battery if u can format phone with box power cable?.
now u have 2 choice
1.format ur phone with box power cable then test with battery
2.click " Cable Define " then define correct GND from ur phone.
enjoy
SE
Old 06-17-2008, 07:53   #6 (permalink)
Member: 478839
as u say but problem is that try to understand when i connect box it ok but with power cable connet to phone +ve box disconnect & box led continus blinking pwr rx tx pwr rx tx but when i disconnced my box connect again box connected
but with battery i can found pressing on off key rx tx cable define
but i can't format with battery so please give me right solution
i am not going to purchase another spiderman but i am going to purchasing pin finder for infinity it is best or not please suggest me...
thankyou.............
Old 06-17-2008, 08:30   #7 (permalink)
Member: 637177
Sonork: 100.103098
Thanks Meter: 8,663
@harisingh
check spiderman main cable. if have another one.can check it.also you can contact your reseller for help.
The Following User Says Thank You to jack-china For This Useful Post:
Old 06-17-2008, 13:33   #8 (permalink)
Member: 470292
Thanks Meter: 147
I was facing the same so I format my windows and reinstall my windows and all drivers my problem solved...
Old 06-19-2008, 08:41   #9 (permalink)
Member: 794829
Thanks Meter: 9
spiderman usb cable problem
Old 06-26-2008, 18:13   #10 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
I checked USB Cable and problem solved ;D
big problem with my mx key sshreesai MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-31-2010 10:07
big problem in spiderman box mogrem.soft SpiderMan 6 12-13-2008 16:32
Big problem of Spiderman rashel.com SpiderMan 1 09-24-2008 14:16
big big big big big problem with server software zone FuriousGold 1 01-16-2008 17:25
BIG BIG BIG problem with SPC2 and VKLAY wael_nasreddine E-Gold Based Phones 2 12-22-2003 22:23
Page generated in 0.17540 seconds with 11 queries
