06-11-2008, 06:56 | #1 (permalink) |
Junior Member Join Date: Mar 2007
Member: 478839 Status: Offline Thanks Meter: 0 | big problem with spiderman i have problem with spiderman 68047300 error on onboard usb port but in pci usb box is connected using version v 2.40 but when i connect mobile & then cable for battery connector red to +ve & black -ve box beep & disconnected(searchasing rx tx on box) i have connected 4 to 5 mobile but problem is same then show error 68047300 big problem sending to spiderman but when i try with mobile battery it search rx tx cable but with using battery i can't format flash please give me soulation or give me advise to purchase new box i have update it it shows v 2.30 before it was v 2.18 i already posted 2 thread before . thanks please give me solution............................... |
06-11-2008, 10:28 | #3 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: china
Member: 637177 Status: Offline Sonork: 100.103098 Thanks Meter: 8,663 | Quote:
if the power cable red connect to back or Conductor connecting through other,box will give you beep,so you need check phone connect is good check use this for connect phone,see the photo | |
06-11-2008, 19:31 | #4 (permalink) |
Member: 478839 Status: Offline Thanks Meter: 0 | i did that with this connect cable with mobile spiderman losting driver when i unplug & plug it again with not connect cable spider dected by comp ok show all info. but with battery it search phone rx tx but i cant format mobile with battery because mobile started i can sand my box u sir u chack it may be technical fault. for better support... |
06-14-2008, 07:34 | #5 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: khonkean,thailand
Member: 10084 Status: Offline Thanks Meter: 283 | Quote:
now u have 2 choice 1.format ur phone with box power cable then test with battery 2.click " Cable Define " then define correct GND from ur phone. enjoy BR SE | |
06-17-2008, 07:53 | #6 (permalink) |
Member: 478839 Status: Offline Thanks Meter: 0 | as u say but problem is that try to understand when i connect box it ok but with power cable connet to phone +ve box disconnect & box led continus blinking pwr rx tx pwr rx tx but when i disconnced my box connect again box connected but with battery i can found pressing on off key rx tx cable define but i can't format with battery so please give me right solution i am not going to purchase another spiderman but i am going to purchasing pin finder for infinity it is best or not please suggest me... thankyou............. |
06-17-2008, 08:30 | #7 (permalink) |
Member: 637177 Status: Offline Sonork: 100.103098 Thanks Meter: 8,663 | @harisingh check spiderman main cable. if have another one.can check it.also you can contact your reseller for help. |
The Following User Says Thank You to jack-china For This Useful Post: |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
big problem in spiderman box | mogrem.soft | SpiderMan | 6 | 12-13-2008 16:32 |
Big problem of Spiderman | rashel.com | SpiderMan | 1 | 09-24-2008 14:16 |
big big big big big problem with server | software zone | FuriousGold | 1 | 01-16-2008 17:25 |
BIG BIG BIG problem with SPC2 and VKLAY | wael_nasreddine | E-Gold Based Phones | 2 | 12-22-2003 22:23 |
