03-25-2008, 07:23 | #1 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | HELP N75 Unlock now DEAD!! here's the logs from JAF Quote:
Any idea? TIA | |
03-25-2008, 08:15 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kasamiko Hi,, you need thin syringe needle and microscope. Under micrsocope or magnyfying glass,, just remove the excess LEAD from the BGA Balls that is shorting either the CLK or the AD8. After you have cleaned it, the phone will power ON and you dont need to flash it with JAF. Just continue to unlock it with AdvanceBox. The BGA Balls can be easily damaged due to too much pressure... but you can also easily repair it if you first remove the Memory Card holder so that you can access the BGA Balls easily. Don't worry, if you are able to clean the excess LEAD, then you will fix your phone. That is all to it ;-) B.R. X-Shadow |
V3re Pls Help Unlocking Now Dead, but it can detect!!! | dmaetrey | Smart-Clip | 2 | 06-23-2009 13:23 |
Please help me K1s unlock now dead.. | Rey69 | Smart-Clip | 10 | 11-29-2008 12:56 |
itel t206 unlock now dead | sharmin | Infinity-Box | 4 | 09-22-2008 20:28 |
Motorola C975 failed unlocking, now dead | therrywenceslas | Motorola Hardware Repair | 2 | 09-07-2007 12:36 |
gd35 for unlock ,,,,,now DEAD, pls HELP | PTR999 | Panasonic | 0 | 10-13-2003 20:55 |
