03-05-2014, 20:07 | #1 (permalink) |
Insane Poster Join Date: Jan 2013 Location: England west yorkshire
Member: 1868314 Status: Offline Sonork: 100.1626287 Thanks Meter: 7 | blackberry 9320 mep0 unlocking fail help [SOLVED & UNLOCKED] see below 18:53:13 > BlackBerry 9320 Curve READ INFO: START! 18:55:45 > Searching for phone: TIMEOUT! 18:55:45 > BlackBerry 9320 Curve READ INFO: END! 18:56:43 > BlackBerry 9320 Curve UNLOCK: START! 18:56:44 > Checking server 1: OK! 18:56:44 > Connecting to server: OK! 18:56:45 > Asking server for access: OK! 18:56:45 > Getting activations from server: OK! 18:59:01 > Searching for phone: TIMEOUT! 18:59:02 > Disconnecting from server: OK! 18:59:02 > BlackBerry 9320 Curve UNLOCK: END! |
03-05-2014, 23:05 | #2 (permalink) |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Is not TIME OUT .. or FAIL .. your phone look like not correct connected of some ... how did you make it ? PHONE ON and connect to USB , install drivers also .. |
03-06-2014, 11:22 | #3 (permalink) |
Member: 1868314 Status: Offline Sonork: 100.1626287 Thanks Meter: 7 | yes phone on and connect to usb when i connected 1st time drivers automatic installed and now phone is not asking for drivers. how can i install drivers manually. thanks |
03-06-2014, 11:47 | #5 (permalink) |
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Solved i see in XP , some time need Close the Blackberry manager original tool .. BR we wait your report |
The Following User Says Thank You to julvir For This Useful Post: |
