10-02-2013, 09:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Mauritius Port Louis
Member: 762522 Status: Offline Thanks Meter: 156 | i9000 no network after unlock [Solved] any solution??? anyway of restoring the lock as the option no found on micro box! |
10-03-2013, 11:10 | #7 (permalink) |
Member: 762522 Status: Offline Thanks Meter: 156 | 11:15:58 > VERSION: MICRO-BOX A.I.O. V2.1.5.3 11:15:58 > BOX SN: 59F142F6EAF23D6B BOX FW: 75 11:15:58 > PORT: Android MODE: Adb 11:15:58 > SAMSUNG I9000 READ INFO: START! 11:15:58 > KILLING ADB SERVER (IF RUNNING): 11:15:58 > KILLING ADB SERVER (IF RUNNING): OK! 11:15:58 > SEARCHING FOR PHONE: 11:15:58 > SEARCHING FOR PHONE: OK! 11:15:58 > READING INFO: 11:15:59 > READING INFO: OK! 11:15:59 > CHECKING ROOT: 11:16:04 > CHECKING ROOT: NOT ROOTED! 11:16:04 > PLEASE ALLOW SUPERUSER ACCESS ON PHONE SCREEN OR FROM MENU! 11:16:37 > CHECKING ROOT: 11:16:43 > CHECKING ROOT: NOT ROOTED! 11:16:43 > BRAND: SAMSUNG 11:16:43 > MODEL: GT-I9000 / GT-I9000 11:16:43 > IMEI: 354795048104357 11:16:43 > VERSION: 2.1-UPDATE1 / ECLAIR 11:16:43 > FIRMWARE: GT-I9000-USER / I9000XXJPK 11:16:43 > KERNEL: 2.6.29 (gcc 4.3.1) 11:16:43 > CPU TYPE: S5PC110 / 11:16:43 > SAMSUNG I9000 READ INFO: END! 11:16:55 > VERSION: MICRO-BOX A.I.O. V2.1.5.3 11:16:55 > BOX SN: 59F142F6EAF23D6B BOX FW: 75 11:16:55 > PORT: Android MODE: Adb 11:16:55 > SAMSUNG I9000 UNLOCK: START! 11:16:55 > KILLING ADB SERVER (IF RUNNING): 11:16:55 > KILLING ADB SERVER (IF RUNNING): OK! 11:16:55 > SEARCHING FOR PHONE: 11:16:55 > SEARCHING FOR PHONE: OK! 11:16:55 > READING INFO: 11:16:57 > READING INFO: OK! 11:16:57 > BRAND: SAMSUNG 11:16:57 > MODEL: GT-I9000 / GT-I9000 11:16:57 > IMEI: 354795048104357 11:16:57 > VERSION: 2.1-UPDATE1 / ECLAIR 11:16:57 > FIRMWARE: GT-I9000-USER / I9000XXJPK 11:16:57 > KERNEL: 2.6.29 (gcc 4.3.1) 11:16:57 > CPU TYPE: S5PC110 / ARMv7 11:16:57 > CHECKING ROOT: 11:17:03 > CHECKING ROOT: NOT ROOTED! 11:17:03 > PLEASE WAIT, RUNNING TEMP ROOT: 11:17:19 > PLEASE WAIT, RUNNING TEMP ROOT: OK! 11:17:20 > SEARCHING FOR PHONE: 11:17:20 > SEARCHING FOR PHONE: OK! 11:17:20 > CHECKING ROOT: 11:17:21 > CHECKING ROOT: OK! 11:17:21 > READING DATA: 11:17:46 > READING DATA: OK! 11:17:46 > Backups\SAMSUNG\I9000\I9000_354795048104357_SIMLOC K_2013_09_30_11_17_46.mbf 11:17:46 > SAVING BACKUP: 11:17:46 > SAVING BACKUP: OK! 11:17:46 > SEARCHING SIGNATURE: 11:17:46 > SEARCHING SIGNATURE: OK! 11:17:47 > WRITING DATA: 11:18:18 > WRITING DATA: OK! 11:18:18 > SAMSUNG I9000 UNLOCK: END! 13:23:43 > BOX DISCONNECTED: ERROR! |
10-04-2013, 07:33 | #9 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Nothing is wrong in this log, you may do hard reset and switch the phone from airplane to normal or reflash it with non branded firmware. Your phone is unlocked. WBR, gsm9l |
The Following User Says Thank You to gsm9l For This Useful Post: |
10-04-2013, 07:44 | #10 (permalink) |
Member: 762522 Status: Offline Thanks Meter: 156 | hard reset done...the customer told me he already unlock it once!! it was locked again..n i re-unlock it again....2 times root cause the problem cause the phone come on airplane mode on its own & off on its own |
10-04-2013, 07:50 | #11 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Write another flash and upgrade it from ancient 2.1 to something newer like 2.3.6 WBR, gsm9l |
