11-19-2012, 14:42 | #1591 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Unknown
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | I637 success unlock with Micro Box Code: 13:21:38 > SAMSUNG I617 READ CODES: START! 13:21:40 > READING IMEI: OK! 13:21:40 > READING CPU INFO: OK! 13:21:40 > READING MEMORY INFO: OK! 13:21:40 > READING BLUETOOTH INFO: OK! 13:21:40 > IMEI: 35698303058XXXX 13:21:40 > BLUETOOTH ID: 53 FB 71 A9 D0 60 13:21:40 > CPU ID: 7225A-SNCAAPZM-1235 13:21:40 > MEMORY ID: 00EC:0040 13:21:40 > samsung_K5W2G1GACC-DL60 13:21:41 > READING DATA: OK! 13:21:41 > CALCULATING: OK! 13:21:41 > MCK CODE: 00000000 13:21:41 > NCK CODE: 60815828 13:21:41 > SPCK CODE: 00000000 13:21:41 > SCK CODE: 00000000 13:21:41 > SAMSUNG I617 READ CODES: END! |
11-19-2012, 18:37 | #1592 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 18:21:36 > VERSION: MICRO-BOX A.I.O. V2.1.3.7 Code: 18:21:36 > BLACKBERRY 9320 READ CODES: START! 18:21:36 > READING ACTIVATIONS FROM BOX: OK! 18:21:36 > BLACKBERRY: ACTIVATED! 18:21:52 > SEARCHING FOR PHONE: OK! 18:21:53 > READING IMEI: OK! 18:21:53 > READING SECURITY DATA: OK! 18:21:53 > IMEI: 352659053147242 18:21:53 > SIMLOCK: MEP-05277-005 18:21:54 > CALCULATING: OK! 18:21:54 > IMEI: 352659053147242 18:21:54 > SIMLOCK: MEP-05277-005 18:21:54 > NCK CODE: 5653229725777227 18:21:54 > SPCK CODE: 1745319670238748 18:21:55 > SIM CODE: 0278251869386815 18:21:55 > SUBS CODE: 2992222413198495 18:21:55 > CP CODE: 7914999046524748 18:21:55 > HOW TO: Insert any sim card and power ON phone 18:21:55 > Turn off all wireless connections 18:21:55 > Go to Options/Advanced Options/SIM Card 18:21:55 > Press menu select for show keyboard (if needed) 18:21:55 > Type MEPPD or MEPD (will not see when type) 18:21:55 > Type MEP2 or MEPP2 (will not see when type) 18:21:55 > Enter corresponding mep code 18:21:55 > BLACKBERRY 9320 READ CODES: END! Last edited by gsm9l; 11-21-2012 at 12:56. |
11-19-2012, 18:41 | #1593 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Code: 18:39:15 > alcatel ot-802 calculate code(s): Start! 18:39:15 > model: Ot-802 18:39:15 > imei: 359089032723066 18:39:15 > provider: 2cotfa1 18:39:15 > reading activations from box: Ok! 18:39:15 > alcatel: Activated! 18:39:16 > checking server 1: Ok! 18:39:16 > connecting to server: Ok! 18:39:16 > asking server for access: Accepted! 18:39:17 > sending data to server: Ok! 18:39:17 > receiving data from server: Ok! 18:39:17 > disconnecting from server: Ok! 18:39:17 > model: Ot-802 18:39:17 > imei: 359089032723066 18:39:17 > provider: 2cotfa1 18:39:17 > nck code: 3952226650 18:39:17 > spck code: 4192243865 18:39:17 > nsck code: 4073850766 18:39:17 > cpck code: 4022865667 18:39:17 > if code not accepted please full reset phone and try again! 18:39:17 > full reset: Phone off, press [#]+[power] or [vol up]+[power]! 18:39:17 > alcatel ot-802 calculate code(s): End! Last edited by gsm9l; 11-21-2012 at 13:01. Reason: Code tag added |
11-19-2012, 21:41 | #1594 (permalink) |
Junior Member Join Date: Apr 2008
Member: 754247 Status: Offline Thanks Meter: 1 | Code: 21:12:35 > MANUFACTURER: HUAWEI 21:12:35 > MODEL: U8160 21:12:35 > VERSION: U8160V100R001C02B617 21:12:35 > CHECKING PHONE VERSION: SUPPORTED! 21:12:47 > SWITCHING TO FAST-BOOT MODE: ERROR! 21:12:47 > PLEASE MANUALLY PUT PHONE IN FAST-BOOT MODE! 21:12:47 > POWER OFF PHONE AND DISCONNECT FROM USB CABLE! 21:12:47 > WITH PHONE OFF PRESS VOLUME DOWN + POWER ON! 21:12:47 > KEEP PRESSED FOR ~10 SECONDS AND THEN RECONNECT TO USB! 21:13:20 > WAITING FOR FAST-BOOT MODE: OK! 21:13:21 > SENDING PARAMETERS: OK! 21:13:49 > SEARCHING FOR PHONE: OK! 21:13:49 > READING PARAMETERS: OK! 21:13:49 > READING FLASH INFO: OK! 21:13:49 > FLASH ID: Hynix 4Gbit (ADBC:1055, 1000, 0040, 0800) 21:19:14 > READING DATA: OK! 21:19:14 > BACKUPS\VODAFONE\858 Smart\uHUAWEI_U8160_U8160V100R001C02B617_356652045905617_2012_11_19_21_19_14_SIMLOCK_BKP.mbf 21:19:14 > SAVING BACKUP: OK! 21:19:14 > OTP_IMEI: 356652045905617 21:19:14 > OTP_BT_ADDR: 352340A096CC 21:19:14 > OTP_WIFI_ADDR: 362340A096CC 21:19:14 > ANALIZING SIMLOCK ZONE: OK! 21:19:14 > SIMLOCK STATUS: LOCKED 21:19:15 > WRITING DATA: OK! 21:19:15 > VODAFONE 858 SMART UNLOCK: END! 21:26:19 > GO SUPPORT: START! 21:26:19 > CHECKING SERVER 1: OK! 21:26:19 > CONNECTING TO SERVER: OK! 21:26:20 > ASKING SERVER FOR ACCESS: ACCEPTED! 21:26:21 > GETTING DATA FROM SERVER: OK! 21:26:21 > DISCONNECTING FROM SERVER: OK! 21:26:22 > STARTING WEB SESSION: OK! 21:26:22 > GO SUPPORT: END! Last edited by gsm9l; 11-21-2012 at 13:01. |
The Following User Says Thank You to delikan66 For This Useful Post: |
11-19-2012, 21:47 | #1595 (permalink) |
Member: 754247 Status: Offline Thanks Meter: 1 | vodafone 858 unlocked!!!!! Code: 21:12:35 > MANUFACTURER: HUAWEI 21:12:35 > MODEL: U8160 21:12:35 > VERSION: U8160V100R001C02B617 21:12:35 > CHECKING PHONE VERSION: SUPPORTED! 21:12:47 > SWITCHING TO FAST-BOOT MODE: ERROR! 21:12:47 > PLEASE MANUALLY PUT PHONE IN FAST-BOOT MODE! 21:12:47 > POWER OFF PHONE AND DISCONNECT FROM USB CABLE! 21:12:47 > WITH PHONE OFF PRESS VOLUME DOWN + POWER ON! 21:12:47 > KEEP PRESSED FOR ~10 SECONDS AND THEN RECONNECT TO USB! 21:13:20 > WAITING FOR FAST-BOOT MODE: OK! 21:13:21 > SENDING PARAMETERS: OK! 21:13:49 > SEARCHING FOR PHONE: OK! 21:13:49 > READING PARAMETERS: OK! 21:13:49 > READING FLASH INFO: OK! 21:13:49 > FLASH ID: Hynix 4Gbit (ADBC:1055, 1000, 0040, 0800) 21:19:14 > READING DATA: OK! 21:19:14 > BACKUPS\VODAFONE\858 Smart\uHUAWEI_U8160_U8160V100R001C02B617_356652045905617_2012_11_19_21_19_14_SIMLOCK_BKP.mbf 21:19:14 > SAVING BACKUP: OK! 21:19:14 > OTP_IMEI: 356652045905617 21:19:14 > OTP_BT_ADDR: 352340A096CC 21:19:14 > OTP_WIFI_ADDR: 362340A096CC 21:19:14 > ANALIZING SIMLOCK ZONE: OK! 21:19:14 > SIMLOCK STATUS: LOCKED 21:19:15 > WRITING DATA: OK! 21:19:15 > VODAFONE 858 SMART UNLOCK: END! 21:26:19 > GO SUPPORT: START! 21:26:19 > CHECKING SERVER 1: OK! 21:26:19 > CONNECTING TO SERVER: OK! 21:26:20 > ASKING SERVER FOR ACCESS: ACCEPTED! 21:26:21 > GETTING DATA FROM SERVER: OK! 21:26:21 > DISCONNECTING FROM SERVER: OK! 21:26:22 > STARTING WEB SESSION: OK! 21:26:22 > GO SUPPORT: END! Last edited by gsm9l; 11-21-2012 at 12:54. Reason: Code tag added |
11-21-2012, 12:45 | #1596 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Code: 12:33:40 > VERSION: MICRO-BOX A.I.O. V2.1.3.7 12:33:40 > BOX SN: Nadoui 12:33:40 > SAMSUNG N7100 READ INFO: START! 12:33:40 > KILLING ADB SERVER (IF RUNNING): OK! 12:33:40 > SEARCHING FOR PHONE: OK! 12:33:42 > READING INFO: OK! 12:33:48 > CHECKING ROOT: OK! 12:33:48 > BRAND: SAMSUNG 12:33:48 > MODEL: GT-N7100 / T03G 12:33:48 > BOOT LOADER: N7100XXALIE 12:33:48 > VERSION: 4.1.1 / JRO03C 12:33:48 > FIRMWARE: T03GXX-USER / N7100XXALIE 12:33:48 > KERNEL: 3.0.31-199846 (gcc 4.4.3) 12:33:48 > CPU TYPE: EXYNOS4 / ARMv7 12:33:49 > SAMSUNG N7100 READ INFO: END! 12:34:13 > VERSION: MICRO-BOX A.I.O. V2.1.3.7 12:34:13 > BOX SN: 56B8F7424C67AA9B BOX FW: 75 12:34:13 > SAMSUNG N7100 UNLOCK: START! 12:34:13 > KILLING ADB SERVER (IF RUNNING): OK! 12:34:13 > SEARCHING FOR PHONE: OK! 12:34:15 > READING INFO: OK! 12:34:15 > BRAND: SAMSUNG 12:34:15 > MODEL: GT-N7100 / T03G 12:34:15 > BOOT LOADER: N7100XXALIE 12:34:15 > VERSION: 4.1.1 / JRO03C 12:34:15 > FIRMWARE: T03GXX-USER / N7100XXALIE 12:34:15 > KERNEL: 3.0.31-199846 (gcc 4.4.3) 12:34:15 > CPU TYPE: EXYNOS4 / ARMv7 12:34:22 > CHECKING ROOT: OK! 12:34:56 > READING DATA: OK! 12:34:56 > Backups\SAMSUNG\N7100\GT-N7100 _ T03G__SIMLOCK_2012_11_21_12_34_56.mbf 12:34:56 > SAVING BACKUP: OK! 12:34:57 > SEARCHING SIGNATURE: OK! 12:35:50 > WRITING DATA: OK! 12:35:50 > SAMSUNG N7100 UNLOCK: END! Last edited by gsm9l; 11-21-2012 at 12:52. Reason: Code tag added |
11-23-2012, 12:05 | #1597 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Code: 11:58:57 > ZTE STARTRAIL READ CODES: START! 11:58:57 > CHECKING SERVER 1: OK! 11:58:57 > CONNECTING TO SERVER: OK! 11:58:58 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:58:58 > GETTING CREDIT DATA FROM SERVER: OK! (UNLIMITED) 11:58:58 > USED COM SPEED: 115200! 11:58:58 > READING CPU INFO: OK! 11:58:58 > READING MODEL: OK! 11:58:58 > READING FIRMWARE INFO: OK! 11:58:58 > READING IMEI: OK! 11:58:58 > MODEL: TSNCJOLY 11:58:58 > IMEI: 867469000197946 11:58:58 > FIRMWARE: 725AV1.0.0B13 / 725AV1.0.0B06 11:58:58 > CPU ID: M76XX-TSNCJOLYM-6030 11:58:58 > DATE: Aug 04 2010 / Jul 28 2011 11:58:59 > READING DATA: OK! 11:58:59 > BACKUPS\ZTE\StarTrail_867469000197946_2012_11_23_11_58_59_SIMLOCK_BACKUP.mbf 11:58:59 > SAVING BACKUP: OK! 11:58:59 > EXTRACTING DATA: OK! 11:58:59 > CHECKING SERVER 1: OK! 11:58:59 > CONNECTING TO SERVER: OK! 11:59:00 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:59:00 > SENDING DATA TO SERVER: OK! 11:59:02 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 11:59:02 > DISCONNECTING FROM SERVER: OK! 11:59:02 > NCK: 68161844 - NOT LOCKED - 10 TRY LEFT 11:59:02 > NSCK: 85722034 - NOT LOCKED - 10 TRY LEFT 11:59:02 > SPCK: 41612765 - NOT LOCKED - 10 TRY LEFT 11:59:02 > CPCK: 84726705 - NOT LOCKED - 10 TRY LEFT 11:59:02 > SIM: 75526861 - NOT LOCKED - 10 TRY LEFT 11:59:02 > PHONE CODE: 00000 11:59:02 > RESTARTING PHONE: OK! 11:59:02 > ZTE STARTRAIL READ CODES: END! Last edited by gsm9l; 01-04-2013 at 07:57. Reason: Code tag added |
11-23-2012, 12:05 | #1598 (permalink) |
11-27-2012, 12:50 | #1599 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | S3350 unlocked done... Code: 3:45:51 > SAMSUNG S3350 TEST MODE READ CODES: START! 13:45:53 > ACTIVATING TEST MODE: OK! 13:46:02 > READING IMEI: OK! 13:46:03 > READING SOFTWARE VERSION: OK! 13:46:04 > READING HARDWARE VERSION: OK! 13:46:05 > READING BLUETOOTH ADDRESS: OK! 13:46:06 > IMEI: 353886041760490 13:46:06 > VERSION: S3350XXJL5 13:46:06 > HARDWARE: REV0.600 13:46:06 > MSL ADDRESS: RPZB162656 13:46:06 > BLUETOOTH ID: 78471D-E258E1 13:46:07 > READING PHONE CODE: OK! 13:46:09 > READING DATA: MSL ACTIVE! 13:46:11 > BYPASSING MSL (STEP1): OK! 13:46:17 > READING SIMLOCK DATA: OK! 13:46:18 > CHECKING SERVER 1: OK! 13:46:18 > CONNECTING TO SERVER: OK! 13:46:19 > ASKING SERVER FOR ACCESS: ACCEPTED! 13:46:19 > SENDING DATA TO SERVER: OK! 13:46:24 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 13:46:25 > DISCONNECTING FROM SERVER: OK! 13:46:25 > MCK CODE: #0199*43327134# 13:46:25 > NCK CODE: #0111*69092892# 13:46:25 > SPCK CODE: #0133*00000000# 13:46:25 > SCK CODE: #0121*00000000# 13:46:25 > PCK CODE: #0141*00000000# 13:46:25 > PHONE CODE: 0000 13:46:26 > SAMSUNG S3350 TEST MODE READ CODES: END! |
12-02-2012, 14:41 | #1600 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Pakistan
Member: 170380 Status: Offline Sonork: 100.1577994 Thanks Meter: 3,022 | GT-P7500R Unlock Done Code: 18:37:32 > VERSION MICRO-BOX A.I.O. V2.1.1.2 18:37:32 > SAMSUNG P7500 UNLOCK: START! 18:37:32 > KILLING ADB SERVER (IF RUNNING): OK! 18:37:32 > SEARCHING FOR PHONE: OK! 18:37:33 > READING INFO: OK! 18:37:33 > BRAND: SAMSUNG 18:37:33 > MODEL: GT-P7500R / GT-P7500R 18:37:33 > IMEI: 358194040184136 18:37:33 > BOOT LOADER: P7500XXKG6 18:37:33 > VERSION: 3.1 / HMJ37 18:37:33 > FIRMWARE: GT-P7500R-USER / P7500RUXKH4 18:37:33 > KERNEL: 2.6.36.3 (gcc 4.4.3) 18:37:33 > CPU TYPE: TEGRA / ARMv7 18:37:40 > CHECKING ROOT: OK! 18:37:54 > READING DATA: OK! 18:37:54 > Backups\SAMSUNG\P7500\GT-P7500R _ GT-P7500R_358194040184136_SIMLOCK_2012_12_02_18_37_54.mbf 18:37:54 > SAVING BACKUP: OK! 18:37:54 > SEARCHING SIGNATURE: OK! 18:38:21 > WRITING DATA: OK! 18:38:21 > SAMSUNG P7500 UNLOCK: END! Last edited by gsm9l; 12-03-2012 at 15:28. Reason: Code tag added |
12-06-2012, 13:44 | #1601 (permalink) |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | samsung f270 flashed Code: 16:24:37 > VERSION: MICRO-BOX A.I.O. V2.1.3.8 16:24:37 > BOX SN: BOX FW: 75 16:24:37 > SAMSUNG F270 FLASH MODE WRITE FLASH: START! 16:24:57 > PRESS POWER: TARGET DETECTED! 16:24:58 > SENDING BOOT: OK! 16:24:58 > SET HIGH SPEED: OK! 16:24:58 > COREID: 3239:0000 16:25:21 > SENDING LOADER: OK! 16:25:21 > READING FLASH ID: OK! 16:25:21 > FLASHID: Samsung K5N3217ATA (32Mb) 16:25:21 > D:\software (dongle)\z3x lg samsung\z3x samsung\f270\F270DDHG6.cla 16:25:21 > LOADING CLA FILE: OK! 16:25:21 > D:\software (dongle)\z3x lg samsung\z3x samsung\f270\F270DDHG6.tfs 16:25:22 > LOADING TFS FILE: OK! (WARNING: CONFIGURATION FILE CHECKSUM MISMATCH OR NOT EXIST) 17:03:59 > BINARY DOWNLOADING: OK! 18:03:41 > TFS DOWNLOADING: OK! 18:03:42 > REBOOTING PHONE: OK! 18:03:42 > SAMSUNG F270 FLASH MODE WRITE FLASH: END! Last edited by gsm9l; 12-10-2012 at 10:13. |
12-06-2012, 15:12 | #1602 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | After flash Code: 14:43:19 > GO SUPPORT: START! 14:43:20 > CHECKING SERVER 1: OK! 14:43:20 > CONNECTING TO SERVER: OK! 14:43:21 > ASKING SERVER FOR ACCESS: ACCEPTED! 14:43:29 > GETTING DATA FROM SERVER: OK! 14:43:29 > DISCONNECTING FROM SERVER: OK! 14:43:29 > STARTING WEB SESSION: OK! 14:43:29 > GO SUPPORT: END! 15:05:41 > VERSION: MICRO-BOX A.I.O. V2.1.4.0 15:05:41 > BOX SN: 37D33AE2693EEE80 BOX FW: 75 15:05:41 > SAMSUNG S8600 UNLOCK: START! 15:05:41 > READING MODEL: OK! 15:05:41 > READING IMEI: OK! 15:05:41 > READING VERSION: OK! 15:05:41 > READING FIRMWARE INFO: OK! 15:05:41 > MODEL: GT-S8600 15:05:41 > IMEI: 359516041152713 15:05:41 > VERSION: M7630A-AAEQMRDM-1.0.5011T 1 [Sep 29 2011 14:00:00] 15:05:41 > FIRMWARE: S8600XXKJC/S8600OXAKJB 15:05:41 > UNLOCKING: ERROR!(NOT PATCHED) 15:06:08 > LOADING PATCH FILE: OK! 15:06:13 > SWITCH TO DOWNLOAD MODE: OK! 15:06:13 > DETECTING MODEL: OK! 15:06:13 > SENDING LOADER: OK! 15:06:14 > ERASING: OK! 15:06:48 > WRITING: OK! 15:06:48 > ERASING: OK! 15:06:50 > WRITING: OK! 15:06:50 > ERASING: OK! 15:07:46 > WRITING: OK! 15:08:22 > SEARCHING FOR PHONE: OK! 15:08:22 > READING MODEL: OK! 15:08:22 > READING IMEI: OK! 15:08:23 > READING VERSION: OK! 15:08:23 > READING FIRMWARE INFO: OK! 15:08:23 > MODEL: GT-S8600 15:08:23 > IMEI: 359516041152713 15:08:23 > VERSION: M7630A-AAEQMRDM-1.0.5011T 1 [Sep 29 2011 14:00:00] 15:08:23 > FIRMWARE: S8600XXKJC/S8600OXAKJB 15:08:24 > UNLOCKING: OK! 15:08:25 > SAMSUNG S8600 UNLOCK: END! |
12-07-2012, 20:11 | #1603 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 531113 Status: Offline Thanks Meter: 22 | SAGEM X6-2 UNLOCK DONE Code: 17:46:55 > MODEL: myX6-2 17:46:55 > IMEI: 355450001918299 17:46:55 > FIRMWARE: LA5,1C: 140605 1645 17:46:55 > HASHTABLE: 720101 17:47:01 > PRESS POWER: 17:47:43 > PRESS POWER: OK! 17:47:43 > READING CPU INFO: 17:47:43 > READING CPU INFO: OK! 17:47:43 > CPU: CALYPSO HS 17:47:43 > SENDING LOADER: 17:47:47 > SENDING LOADER: OK! 17:47:47 > SENDING CERTIFICATE: 17:48:21 > SENDING CERTIFICATE: OK! 17:48:21 > WAITING LOADER ANSWER: 17:49:21 > WAITING LOADER ANSWER: OK! 17:49:22 > READING DATA: 17:51:47 > READING DATA: OK! 17:51:47 > DISCONNECTING PHONE 17:51:47 > DISCONNECTING PHONE: OK! 17:51:47 > CHECKING SERVER 1: 17:51:57 > CHECKING SERVER 1: OK! 17:51:57 > CONNECTING TO SERVER: 17:51:57 > CONNECTING TO SERVER: OK! 17:51:57 > ASKING SERVER FOR ACCESS: 17:51:59 > ASKING SERVER FOR ACCESS: ACCEPTED! 17:51:59 > SENDING PHONE DATA TO SERVER: 17:52:00 > SENDING PHONE DATA TO SERVER: OK! 17:52:00 > GETTING CREDIT DATA FROM SERVER: 17:52:01 > GETTING CREDIT DATA FROM SERVER: OK! 17:52:01 > GETTING CREDIT DATA FROM SERVER: OK! (UNLIMITED) 17:52:01 > WAITING FOR SERVER: 17:52:06 > WAITING FOR SERVER: OK! 17:52:06 > CHECKING SERVER 1: 17:52:06 > CHECKING SERVER 1: OK! 17:52:06 > CONNECTING TO SERVER: 17:52:07 > CONNECTING TO SERVER: OK! 17:52:07 > ASKING SERVER FOR ACCESS: 17:52:09 > ASKING SERVER FOR ACCESS: ACCEPTED! 17:52:09 > GETTING CREDIT DATA FROM SERVER: 17:52:10 > GETTING CREDIT DATA FROM SERVER: OK! 17:52:10 > GETTING CREDIT DATA FROM SERVER: OK! (UNLIMITED) 17:52:10 > GETTING CODES DATA FROM SERVER: 17:52:11 > GETTING CODES DATA FROM SERVER: OK! 17:52:11 > MODEL: MYX6-2 IMEI: 355450001918299 CODE: 14564006-73 17:52:11 > GETTING CREDIT DATA FROM SERVER: 17:52:12 > GETTING CREDIT DATA FROM SERVER: OK! 17:52:12 > GETTING CREDIT DATA FROM SERVER: OK! (UNLIMITED) 17:52:12 > SAGEM MYX6-2 READ CODES: END! Last edited by arodney; 12-08-2012 at 00:23. Reason: Change PHP tags to Code Tags = So others Can Read the font |
12-08-2012, 20:21 | #1604 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1696266 Status: Offline Thanks Meter: 17 | zte monte carlo unlocked in few seconds Code: 19:13:40 > VERSION: MICRO-BOX A.I.O. V2.1.3.8 19:13:40 > BOX SN: A764228BD6593856 BOX FW: 75 19:13:40 > ORANGE MONTE CARLO READ CODES: START! 19:13:40 > CHECKING SERVER 1: 19:13:41 > CHECKING SERVER 1: OK! 19:13:41 > CONNECTING TO SERVER: 19:13:41 > CONNECTING TO SERVER: OK! 19:13:41 > ASKING SERVER FOR ACCESS: 19:13:42 > ASKING SERVER FOR ACCESS: ACCEPTED! 19:13:42 > GETTING CREDIT DATA FROM SERVER: 19:13:42 > GETTING CREDIT DATA FROM SERVER: OK! (UNLIMITED) 19:13:43 > USED COM SPEED: 115200! 19:13:43 > READING CPU INFO: 19:13:43 > READING CPU INFO: OK! 19:13:43 > READING MODEL: 19:13:43 > READING MODEL: OK! 19:13:43 > READING FIRMWARE INFO: 19:13:43 > READING FIRMWARE INFO: OK! 19:13:43 > READING IMEI: 19:13:43 > READING IMEI: OK! 19:13:43 > MODEL: TSNCJOLY 19:13:43 > IMEI: 86854300xxxxxxx 19:13:43 > FIRMWARE: SP_P743TV1.0.0B07 / SP_P743TV1.0.0B03 19:13:43 > CPU ID: M76XX-TSNCJOLYM-6050 19:13:43 > DATE: Oct 26 2010 / Dec 29 2011 19:13:43 > READING DATA: 19:13:44 > READING DATA: OK! 19:13:44 > BACKUPS\ORANGE\MONTE CARLO_86854300xxxxxxx_2012_12_08_19_13_44_SIMLOCK_BACKUP.mbf 19:13:44 > SAVING BACKUP: 19:13:44 > SAVING BACKUP: OK! 19:13:44 > EXTRACTING DATA: 19:13:45 > EXTRACTING DATA: OK! 19:13:45 > CHECKING SERVER 1: 19:13:45 > CHECKING SERVER 1: OK! 19:13:45 > CONNECTING TO SERVER: 19:13:46 > CONNECTING TO SERVER: OK! 19:13:46 > ASKING SERVER FOR ACCESS: 19:13:47 > ASKING SERVER FOR ACCESS: ACCEPTED! 19:13:47 > SENDING DATA TO SERVER: 19:13:47 > SENDING DATA TO SERVER: OK! 19:13:47 > CALCULATING [BY SERVER] PLEASE WAIT: 19:13:52 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 19:13:52 > DISCONNECTING FROM SERVER: OK! 19:13:52 > RESETING COUNTERS: 19:13:52 > RESETING COUNTERS: OK! 19:13:52 > NCK: 9513699835963055 - LOCKED - 10 TRY LEFT 19:13:52 > NSCK: 4145349112017445 - NOT LOCKED - 10 TRY LEFT 19:13:52 > SPCK: 0937007107829647 - NOT LOCKED - 10 TRY LEFT 19:13:52 > CPCK: 8010852927415541 - NOT LOCKED - 10 TRY LEFT 19:13:52 > SIM: 5934168201697504 - NOT LOCKED - 10 TRY LEFT 19:13:52 > NETWORK: 214-03 19:13:52 > PHONE CODE: 00000 19:13:52 > RESTARTING PHONE: 19:13:52 > RESTARTING PHONE: OK! 19:13:52 > ORANGE MONTE CARLO READ CODES: END! Last edited by gsm9l; 12-10-2012 at 10:13. Reason: Code tag added |
12-16-2012, 11:44 | #1605 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: Poland Age: 39
Member: 157756 Status: Offline Thanks Meter: 14 | i9100 4.1.2 unlock Quote:
Put in this thread all successfull story with Cyclone-box | NADEEM GONDAL | Cyclonebox | 3058 | 05-24-2019 07:07 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
