05-04-2011, 15:22 | #1202 (permalink) |
No Life Poster Join Date: Dec 2006 Location: ! Age: 39
Member: 414755 Status: Offline Sonork: quickgsm Thanks Meter: 389 | Code: 16:00:53 > Ready... 16:00:58 > CHECK LOCK START! 16:00:58 > Detecting serial ports...OK! COM9 RIM Virtual Serial Port v2 COM10 RIM Virtual Serial Port v2 COM32 LGE EVDOM USB Modem #2 COM33 LGE EVDOM USB Serial DM Port COM34 LGE EVDOM USB Serial Port COM87 HUAWEI Mobile Connect - 3G Modem #3 COM88 HUAWEI Mobile Connect - 3G Application Interface COM89 HUAWEI Mobile Connect - 3G PC UI Interface 16:00:58 > Searching for modem...FOUND! (COM87) 16:01:07 > Reading info...OK! 16:01:08 > MODEL: E1550 16:01:08 > IMEI: 352445xxxxxxxxx 16:01:12 > Reading lock status...OK! - LOCKED! 16:01:12 > CHECK LOCK END! 16:01:12 > Ready... 16:08:41 > UNLOCK START! 16:08:41 > Detecting serial ports...OK! COM6 HUAWEI Mobile Connect - 3G Modem COM7 HUAWEI Mobile Connect - 3G Application Interface COM9 RIM Virtual Serial Port v2 COM10 RIM Virtual Serial Port v2 COM32 LGE EVDOM USB Modem #2 COM33 LGE EVDOM USB Serial DM Port COM34 LGE EVDOM USB Serial Port COM71 HUAWEI Mobile Connect - 3G PC UI Interface 16:08:42 > Searching for modem...FOUND! (COM6) 16:08:52 > Reading info...OK! 16:08:52 > MODEL: E1550 16:08:52 > IMEI: 352445xxxxxxxxx 16:08:57 > Reading lock status...OK! 16:08:58 > Writing unlock data...OK! 16:08:58 > MODEM WAS UNLOCKED SUCCESFULLY! 16:08:58 > UNLOCK END! 16:08:59 > Ready... Last edited by gsm9l; 06-09-2011 at 20:51. Reason: Code tag added |
The Following User Says Thank You to quickgsm For This Useful Post: |
05-04-2011, 21:51 | #1203 (permalink) |
No Life Poster Join Date: Nov 2008 Location: bulgaria
Member: 903701 Status: Offline Sonork: leo7 Thanks Meter: 119 | 9630 unlock ok Code: 23:21:11 > version micro-box a.i.o. V1.0.8.9 23:21:12 > blackberry 9630 read codes: Start! 23:21:12 > checking server 1: Ok! 23:21:22 > connecting to server: Ok! 23:21:23 > asking server for access: Accepted! 23:21:29 > checking htc_bb activation: Ok! 23:21:29 > htc_bb: Activated 23:22:03 > searching for phone: Ok! 23:22:05 > reading imei: Ok! 23:22:09 > reading security data: Ok! 23:22:09 > imei: 980070002245279 23:22:09 > simlock: Mep-15326-002 23:22:13 > checking server 1: Ok! 23:22:23 > connecting to server: Ok! 23:22:34 > asking server for access: Accepted! 23:22:34 > sending phone data to server: Ok! 23:22:53 > calculating [by server] please wait: Ok! 23:22:53 > imei: 980070002245279 23:22:53 > simlock: Mep-15326-002 23:22:53 > nck code: 34238678 (mep2) 23:22:53 > sp code: 41717232 (mep4) 23:22:53 > blackberry 9630 read codes: End! Last edited by gsm9l; 06-09-2011 at 20:51. Reason: Code tag added |
The Following User Says Thank You to iliya _angelov For This Useful Post: |
05-11-2011, 10:19 | #1207 (permalink) |
Registered User Join Date: Sep 2007 Location: RO, Bucuresti
Member: 595504 Status: Offline Sonork: 100.1580419 Thanks Meter: 249 | HTC WILDFIRE SUCCES DIRECT UNLOCK VERSION 2.2.1 Code: 11:49:09 > VERSION MICRO-BOX A.I.O. V1.0.8.9 11:49:09 > HTC WILDFIRE READ INFO: START! 11:49:10 > KILLING ADB SERVER (IF RUNNING): OK! 11:49:10 > SEARCHING FOR PHONE: OK! 11:49:11 > READING INFO: OK! 11:49:17 > CHECKING ROOT: NOT ROOTED! 11:49:17 > MODEL: PC4910000 / HTC Wildfire / buzz 11:49:17 > CID: HTC__032 11:49:17 > BOOT LOADER: 1.01.0001 11:49:17 > VERSION: 2.2.1 / FRG83D 11:49:17 > FIRMWARE: 2.22.405.1 / 13.55.55.24H_3.35.20.10 11:49:17 > KERNEL: 2.6.32.21-g0f9e9b5 (gcc 4.4.0) 11:49:17 > CPU TYPE: MSM7K / ARMv6 11:49:17 > HTC WILDFIRE READ INFO: END! 11:49:21 > VERSION MICRO-BOX A.I.O. V1.0.8.9 11:49:21 > HTC WILDFIRE UNLOCK: START! 11:49:22 > CHECKING SERVER 1: OK! 11:49:22 > CONNECTING TO SERVER: OK! 11:49:22 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:49:23 > CHECKING HTC_BB ACTIVATION: OK! 11:49:23 > HTC_BB: ACTIVATED 11:49:23 > KILLING ADB SERVER (IF RUNNING): OK! 11:49:23 > SEARCHING FOR PHONE: OK! 11:49:24 > READING INFO: OK! 11:49:24 > MODEL: PC4910000 / HTC Wildfire / buzz 11:49:24 > CID: HTC__032 11:49:24 > BOOT LOADER: 1.01.0001 11:49:24 > VERSION: 2.2.1 / FRG83D 11:49:24 > FIRMWARE: 2.22.405.1 / 13.55.55.24H_3.35.20.10 11:49:24 > KERNEL: 2.6.32.21-g0f9e9b5 (gcc 4.4.0) 11:49:24 > CPU TYPE: MSM7K / ARMv6 11:49:29 > CHECKING ROOT: NOT ROOTED! 11:49:39 > RUNNING TEMP ROOT: OK! 11:49:39 > SEARCHING FOR PHONE: OK! 11:49:40 > CHECKING ROOT: OK! 11:50:00 > SENDING LOADER: OK! 11:50:09 > WAITING LOADER ANSWER: OK! 11:50:27 > READING DATA: OK! 11:50:29 > SEARCHING LOCK BLOCK: OK! 11:50:29 > CHECKING SERVER 1: OK! 11:50:29 > CONNECTING TO SERVER: OK! 11:50:30 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:50:31 > SENDING PHONE DATA TO SERVER: OK! 11:50:35 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 11:50:35 > MODEL: PC4910000 / HTC Wildfire / buzz 11:50:35 > IMEI: 35579704027775001 11:50:35 > CID: HTC__032 11:50:35 > BOOT LOADER: 1.01.0001 11:50:35 > VERSION: 2.2.1 / FRG83D 11:50:35 > FIRMWARE: 2.22.405.1 / 13.55.55.24H_3.35.20.10 11:50:35 > KERNEL: 2.6.32.21-g0f9e9b5 (gcc 4.4.0) 11:50:35 > CPU TYPE: MSM7K / ARMv6 11:50:35 > FLASH ID: 5500BCEC 11:50:35 > NCK CODE: 67740632 (SIM network unlock PIN) 11:50:35 > NSCK CODE: UNLOCKED (SIM network subset unlock PIN) 11:50:35 > SPCK CODE: UNLOCKED (SIM service provider unlock PIN) 11:50:35 > CPCK CODE: UNLOCKED (SIM corporate unlock PIN) 11:50:53 > UNLOCKING: OK! 11:50:59 > HTC WILDFIRE UNLOCK: END! Last edited by gsm9l; 06-09-2011 at 20:52. Reason: Code tag added |
The Following User Says Thank You to ServiceTEL For This Useful Post: |
05-14-2011, 09:45 | #1209 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: masantol, pampanga.ph
Member: 268175 Status: Offline Thanks Meter: 198 | s5620 unlock via uart cable. Quote:
05-14-2011, 11:37 | #1210 (permalink) |
Registered User Join Date: Jul 2008
Member: 820730 Status: Offline Thanks Meter: 7 | Code: 23:01:45 > samsung s5600v read codes: End! 23:02:30 > version micro-box a.i.o. V1.0.8.8 23:02:30 > samsung s5600 read codes: Start! 23:02:30 > reading imei: 23:02:30 > reading imei: Ok! 23:02:30 > reading firmware info: 23:02:30 > reading firmware info: Ok! 23:02:31 > reading cpu info: 23:02:31 > reading cpu info: Ok! 23:02:31 > reading hardware info: 23:02:31 > reading hardware info: Ok! 23:02:31 > reading bluetooth info: 23:02:31 > reading bluetooth info: Ok! 23:02:31 > imei: 352641033359048 23:02:31 > firmware: S5600bvida 23:02:31 > hardware: Mp 0.600 23:02:31 > bluetooth id: 00 25 67 6b d6 67 23:02:31 > cpu id: M6281a-klrzr-4.0.9640_1s 23:02:31 > reading msl data: 23:06:06 > reading msl data: Ok! 23:06:06 > bypassing msl: 23:06:06 > bypassing msl: Ok! 23:06:06 > reading codes data: 23:06:08 > reading codes data: Ok! 23:06:08 > checking server 1: 23:06:08 > checking server 1: Ok! 23:06:08 > connecting to server: 23:06:09 > connecting to server: Ok! 23:06:09 > asking server for access: 23:06:10 > asking server for access: Accepted! 23:06:10 > sending data to server: 23:06:11 > sending data to server: Ok! 23:06:11 > calculating [by server] please wait: 23:06:25 > calculating [by server] please wait: Ok! 23:06:25 > freeze code: 41905727 23:06:25 > net code: 27397472 23:06:25 > sp code: 00000000 23:06:25 > cp code: 00000000 23:06:25 > sim code: 00000000 23:06:25 > disconnecting from server: Ok! 23:06:25 > samsung s5600 read codes: End! Code: 23:20:56 > version micro-box a.i.o. V1.0.8.8 23:20:56 > samsung s5620 read codes: Start! 23:20:56 > press power: 23:22:15 > press power: Aborted! 23:22:15 > samsung s5620 read codes: End! 23:22:59 > version micro-box a.i.o. V1.0.8.8 23:22:59 > samsung s5620 read codes: Start! 23:22:59 > press power: 23:23:46 > press power: Aborted! 23:23:46 > samsung s5620 read codes: End! 23:23:57 > box disconnected: Error! 23:28:52 > get credit/activation: Start! 23:28:54 > checking server 1: 23:28:54 > checking server 1: Ok! 23:28:55 > connecting to server: 23:28:55 > connecting to server: Ok! 23:28:55 > asking server for access: 23:28:57 > asking server for access: Accepted! 23:28:57 > checking htc activation: 23:28:59 > checking htc activation: Ok! 23:28:59 > htc: Not activated 23:28:59 > checking lg activation: 23:29:00 > checking lg activation: Ok! 23:29:00 > lg: Not activated 23:29:00 > checking sagem activation: 23:29:01 > checking sagem activation: Ok! 23:29:01 > sagem: Activated 23:29:01 > getting credit data from server: 23:29:03 > getting credit data from server: Ok! 23:29:03 > credit free: 9 23:29:03 > credit used: 10 23:29:03 > credit limit: 10 23:29:03 > disconnecting from server: Ok! 23:29:03 > get credit/activation: End! 23:29:32 > version micro-box a.i.o. V1.0.8.8 23:29:32 > samsung s5620 read codes: Start! 23:29:33 > press power: 23:30:30 > press power: Ok! 23:30:30 > sending loader: 23:31:01 > sending loader: Ok! 23:31:02 > reading data: 23:31:09 > reading data: Ok! 23:33:13 > model: Gt-s5620 23:33:13 > country code: Ora 23:33:13 > firmware: S5620bvje1_oraje1 23:33:13 > phone sn: 86190000065122 23:33:13 > date: 2010-05-19 23:33:13 > memory name: K5r4g1gacm(s5620)s 23:33:13 > checking server 1: 23:33:14 > checking server 1: Ok! 23:33:14 > connecting to server: 23:33:14 > connecting to server: Ok! 23:33:14 > asking server for access: 23:33:18 > asking server for access: Accepted! 23:33:18 > sending data to server: 23:33:20 > sending data to server: Ok! 23:33:20 > calculating [by server] please wait: 23:33:31 > calculating [by server] please wait: Ok! 23:33:31 > freeze code: 74735819 23:33:31 > net code: 75725851 23:33:31 > sp code: 00000000 23:33:31 > cp code: 00000000 23:33:31 > sim code: 00000000 23:33:31 > disconnecting from server: Ok! 23:33:31 > samsung s5620 read codes: End! 23:33:32 > box disconnected: Error! Last edited by gsm9l; 06-09-2011 at 20:53. Reason: Code tag added |
05-15-2011, 22:01 | #1211 (permalink) |
Member: 903701 Status: Offline Sonork: leo7 Thanks Meter: 119 | htc desire unlock ok Code: 19:40:42 > VERSION MICRO-BOX A.I.O. V1.0.8.9 19:40:43 > HTC DESIRE READ CODES: START! 19:40:47 > CHECKING SERVER 1: OK! 19:40:47 > CONNECTING TO SERVER: OK! 19:40:48 > ASKING SERVER FOR ACCESS: ACCEPTED! 19:40:51 > CHECKING HTC_BB ACTIVATION: OK! 19:40:51 > HTC_BB: ACTIVATED 19:41:02 > KILLING ADB SERVER (IF RUNNING): OK! 19:41:06 > SEARCHING FOR PHONE: OK! 19:41:37 > READING INFO: OK! 19:41:38 > MODEL: HTC Desire / bravo 19:41:38 > BOOT LOADER: 0.83.0001 19:41:38 > VERSION: 2.1-update1 / ERE27 19:41:38 > FIRMWARE: 1.22.771.1 / 32.41.00.32U_4.08.00.09 19:41:38 > KERNEL: 2.6.29-54b7033a (gcc 4.4.0) 19:41:38 > CPU TYPE: QSD8K / ARMv7 19:41:38 > CARD ID: 1B534D3030303030107613CC8100A64E 19:41:52 > CHECKING ROOT: NOT ROOTED! 19:43:13 > RUNNING TEMP ROOT: OK! 19:43:13 > SEARCHING FOR PHONE: OK! 19:43:18 > CHECKING ROOT: OK! 19:50:17 > SENDING LOADER: OK! 19:50:26 > WAITING LOADER ANSWER: OK! 19:50:46 > READING DATA: OK! 19:51:07 > SEARCHING LOCK BLOCK: OK! 19:51:07 > CHECKING SERVER 1: OK! 19:51:07 > CONNECTING TO SERVER: OK! 19:51:08 > ASKING SERVER FOR ACCESS: ACCEPTED! 19:51:08 > SENDING PHONE DATA TO SERVER: OK! 19:51:11 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 19:51:11 > MODEL: HTC Desire / bravo 19:51:11 > IMEI: 35383304183825800 19:51:11 > BOOT LOADER: 0.83.0001 19:51:11 > VERSION: 2.1-update1 / ERE27 19:51:11 > FIRMWARE: 1.22.771.1 / 32.41.00.32U_4.08.00.09 19:51:11 > KERNEL: 2.6.29-54b7033a (gcc 4.4.0) 19:51:11 > CPU TYPE: QSD8K / ARMv7 19:51:11 > FLASH ID: 5510BCAD 19:51:11 > CARD ID: 1B534D3030303030107613CC8100A64E 19:51:11 > NCK CODE: 99859488 (SIM network unlock PIN) 19:51:11 > NSCK CODE: UNLOCKED (SIM network subset unlock PIN) 19:51:11 > SPCK CODE: UNLOCKED (SIM service provider unlock PIN) 19:51:11 > CPCK CODE: UNLOCKED (SIM corporate unlock PIN) 19:51:12 > HTC DESIRE READ CODES: END! Last edited by gsm9l; 06-09-2011 at 20:55. Reason: Code tag added |
05-16-2011, 20:54 | #1212 (permalink) |
Freak Poster Join Date: Jun 2008 Location: algeria
Member: 793926 Status: Offline Thanks Meter: 67 | M8800 unlocked thanks microbox Code: 18:37:13 > samsung m8800 read codes: Start! 18:37:13 > searching for phone: 18:37:13 > searching for phone: Found! 18:37:13 > reading imei: 18:37:13 > reading imei: Ok! 18:37:13 > reading firmware info: 18:37:13 > reading firmware info: Ok! 18:37:13 > reading cpu info: 18:37:13 > reading cpu info: Ok! 18:37:14 > reading hardware info: 18:37:14 > reading hardware info: Ok! 18:37:14 > reading bluetooth info: 18:37:14 > reading bluetooth info: Ok! 18:37:14 > imei: 356325022881990 18:37:14 > firmware: M8800aehk1 18:37:14 > hardware: Mp 0.500 18:37:14 > bluetooth id: 00 23 d7 58 36 09 18:37:14 > cpu id: M6281a-klrz-4.0.96152s 18:37:14 > reading security data : 18:37:20 > reading security data: Ok! 18:37:20 > reading codes data: 18:37:23 > reading codes data: Ok! 18:37:23 > checking server 1: 18:37:24 > checking server 1: Ok! 18:37:24 > connecting to server: 18:37:25 > connecting to server: Ok! 18:37:25 > asking server for access: 18:37:30 > asking server for access: Accepted! 18:37:30 > sending data to server: 18:37:31 > sending data to server: Ok! 18:37:31 > calculating [by server] please wait: 18:37:49 > calculating [by server] please wait: Ok! 18:37:49 > freeze code: 53636085 18:37:49 > net code: 38364139 18:37:49 > sp code: 00000000 18:37:49 > cp code: 00000000 18:37:49 > sim code: 00000000 18:37:50 > disconnecting from server: Ok! 18:37:50 > samsung m8800 read codes: End! Last edited by gsm9l; 06-09-2011 at 20:56. |
05-19-2011, 15:11 | #1215 (permalink) |
Member: 903701 Status: Offline Sonork: leo7 Thanks Meter: 119 | ot-222 unlock Code: 16:07:15 > version micro-box a.i.o. V2.0.0.1 16:07:16 > alcatel ot-222 calculate code(s): Start! 16:07:16 > model: Ot-222 16:07:16 > imei: 355916037913587 16:07:16 > provider: 222x-2erges1 16:07:16 > checking server 1: Ok! 16:07:16 > connecting to server: Ok! 16:07:17 > asking server for access: Accepted! 16:07:18 > checking activations: Ok! 16:07:18 > alcatel: Activated! 16:07:18 > checking server 1: Ok! 16:07:18 > connecting to server: Ok! 16:07:19 > asking server for access: Accepted! 16:07:19 > sending data to server: Ok! 16:07:20 > receiving data from server: Ok! 16:07:20 > disconnecting from server: Ok! 16:07:20 > model: Ot-222 16:07:20 > imei: 355916037913587 16:07:20 > provider: 222x-2erges1 16:07:20 > nck code: 3369022018 16:07:20 > nsck code: 2327665537 16:07:20 > spck code: 0110025224 16:07:20 > cpck code: 2327665537 16:07:20 > cck code: 2327665537 16:07:20 > pck code: 2327665537 16:07:20 > alcatel ot-222 calculate code(s): End! Last edited by gsm9l; 06-09-2011 at 20:56. Reason: Code tag added |
Put in this thread all successfull story with Cyclone-box | NADEEM GONDAL | Cyclonebox | 3058 | 05-24-2019 07:07 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
