10-10-2008, 03:12 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: U.K www.PhoneandIT.com
Member: 59991 Status: Offline Thanks Meter: 40 | Windows Vista 32bits - Windows 7 32bits ! Installation of driver here ! To encouter this problem, first install your box with normal drivers provided in rar file from microbox. after this if you cannot get to read serial number of box as it says "Not Found" then follow this procedure Go to device manager. click on + with PORTS Double click on AVL VT port after installation with normal driver procedure, It will come under ports section. 1. Double click on allocated Port 2. Go to Drivers and select UPDATE driver. select YES THIS TIME ONLY 3. Choose "Install from List or specific Location". click NEXT 4. select "Don't search I will select the dirver to Install" and click NEXT 5. Now click on "SHOW COMPATIBLE DRIVER" and then Click "HAVE DISK" 6. NOW BROWSE to the folder where the orignaly drivers are present. Now you will see MICROBOX under the models.. select and next next next there you go job done. Good Luck.. Last edited by midou01; 10-10-2008 at 10:09. |
The Following 13 Users Say Thank You to pakstar For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
buy your GSM here | midlandcellular | Main Sales Section | 0 | 09-04-1999 17:14 |
