01-18-2011, 11:40 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Indonesia Age: 43
Member: 119552 Status: Offline Thanks Meter: 33 | C-3222 security code can't connect[SOLVED] Follow procedure hold down key and plug usb .. but no responce anything Driver autoinstall samsung.. modem port show up:13 but at comport not show up .. just com1 and com spt .. which com must select one select comport : 1 and speed usb.. Did I Something missing with my step?.. BR PAEDY Last edited by wgmmmx1; 05-03-2011 at 08:54. |
01-18-2011, 12:09 | #2 (permalink) |
Banned Join Date: Jun 2007 Location: Samsung
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | select speed usb and mark unlock + reset phone then press spt mode nad spt will tell you how to connect phone |
The Following User Says Thank You to SPTTEAM For This Useful Post: |
01-18-2011, 12:56 | #3 (permalink) |
Member: 119552 Status: Offline Thanks Meter: 33 | I did try your instruction.. But always show Press Volumn Down And Hold Key And Plug USB Cable. Phone on or off ?.. I did from phone Off.. and nothiing happen.. Try with phone on.. still same problem.. BR Paedy |
01-18-2011, 13:05 | #4 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Phone off withotu battery if nothign happen then you got somethign with windwos becosue after you do this you should see ask windows about drivers. |
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
01-18-2011, 14:14 | #5 (permalink) |
Member: 119552 Status: Offline Thanks Meter: 33 | Ok.. It work's thank.. Actually i do press hold down button and one other button from right side phone together and it work.. security code remove now but menu and letter was a mess.. Should I flash a phone?.. Please fixed a bug.. cause if we just remove a security code then a flash phone it too complicated process.. And i take a look support area and no packets it's indonesian's language.. Thx for a great support.. BR PAEDY |
01-18-2011, 14:28 | #6 (permalink) |
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | its not bug this phone had this problem spt just make unlock and remove security code dont touch phone firmware or other thing Last edited by wgmmmx1; 05-03-2011 at 08:54. |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Orange IL, Nokia 5110 GSM codes... | rosso11 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-05-1999 21:38 |
