07-11-2008, 20:44 | #1 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | First Samsung Box Working On Windows VISTA / SEVEN 32/64bit !! !! This is very good job from SPT TEAM !! !! Like always !! !! New drivers for windows vista/7 32/64bit SPT team tell me that ADD to new installer then without even download seperatly driver all user windows vista 32 or 64bit will can work without problem with SPT !! !! Only egist 1 prolem windows vista got permission manager and if any software want use COM PORT need administrator access and the same situation is with SPT SOFTWARE !! But this is very simple solution that I give on screenshoot !! need run program with ADMIN right and all work very well and without problems !! !! Thanks again SPT TEAM very good work !! !! !! Ooooo I forget most important When you installing SPT software need do this with admin right and run too with admin right. bye Always newest drivers relised by FTDI company http://www.ftdichip.com/Drivers/CDM/...0Certified.zip Wojciech Goralczyk Last edited by wgmmmx1; 08-28-2010 at 14:55. |
The Following 8 Users Say Thank You to wgmmmx For This Useful Post: |
Does the FG USB dongle work on Windows Vista [SOLVED] | gawireless | FuriousGold | 7 | 12-10-2009 22:21 |
box works on windows seven | mj_0990 | The Market Feed Back | 7 | 12-08-2009 15:27 |
Which Boxes Work On WINDOWS 7 ? PLEASE POST! | TheTelecomShop | Hardware Equipments for GSM | 9 | 10-29-2009 22:03 |
The New upgrade is not working on windows Vista | zeeshanawan | UST Pro II | 0 | 01-30-2009 16:21 |
is univerasal box work with windows vista | keeran | Universalbox | 5 | 10-03-2008 14:04 |
