03-07-2014, 13:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2004
Member: 51403 Status: Offline Thanks Meter: 49 | i337 after unlock Wifi problem[ANSWERED] I have problem with two phones i337 and i377m. After reset default EFS and unlock wifi not working. How to repair this problem? |
03-07-2014, 16:18 | #3 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Where you never imagine Age: 42
Member: 80724 Status: Offline Sonork: 100.1610017 Thanks Meter: 42 | Same problem here. I selectected I9505 and connected to the UART cable, and I have this situation: Please Wait Enter Test Mode ... Enter Test Mode OK! Product ID: Unknown Not Support Current Hardware ! Total Time: 12.58 s |
03-07-2014, 17:01 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: XpErTs GsM ® Age: 41
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | Do *#7284# and Select UART as MODEM. *#8080# and select ADB+DM+MODEM and try it again |
The Following User Says Thank You to XpErTsGsM For This Useful Post: |
03-07-2014, 17:19 | #5 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | delete efs folder using root explorer... and repair original imei with factory mode... it will work |
The Following User Says Thank You to vickcar13 For This Useful Post: |
03-07-2014, 17:37 | #6 (permalink) | |
Member: 80724 Status: Offline Sonork: 100.1610017 Thanks Meter: 42 | Quote:
Just to correct, *#0808# then DM+MODEM+ADB. I have choosed GT-I9505. I have setup the phone as you said, and the process came as is: Please Wait Enter Test Mode ... Enter Test Mode OK! S/W Version: I337UCUAMDB Product ID: M9615A-CEFWTAZM-4.0.17062 Please Wait Repair 3G Network Data ... Repair Jobs Done. Total Time: 15.2 s The first try WiFi worked fine, then I could activate the Option WiFi and could select a couple of network and connect and WiFi worked fine. Then I restart the phone to try again and the WiFi did not work anymore, I just select WiFi and it comes in a green/gray color, I mean not completly green, so I cannot activate it. Android version: 4.3 Rom Version: Rom Stock I337UCUEMK2 Baseband version or Modem: I337UCUAMDB Waiting for your reply. Thanks in advance. Very close to solve it. | |
03-07-2014, 17:43 | #7 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | me too have this problem try all and only work same min try connect other red and not work please helpme pd: any have firmware 4.3 i337 for odin Last edited by jmr; 03-07-2014 at 17:49. |
03-09-2014, 17:39 | #9 (permalink) |
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | You're welcome men.. i only post real solutions.. tested and that really works.. otherwise i dont reply just for say something.. sent from my sm-n900 using tapatalk |
03-10-2014, 22:48 | #10 (permalink) |
Member: 80724 Status: Offline Sonork: 100.1610017 Thanks Meter: 42 | 100% solution here. I tried it. Thanks VickCell!! http://forum.gsmhosting.com/vbb/f452...-here-1788263/ |
03-11-2014, 11:48 | #11 (permalink) |
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | User have Repoted This Problem In Many Phones Some is Solved By Repairing Network We Are Working On New Version And Alot Of Models. To Update Security and EFS data Next Update will Solve These Main Issue Till That These Methods Can Help. |
The Following 2 Users Say Thank You to XpErTsGsM For This Useful Post: |
03-11-2014, 16:41 | #12 (permalink) |
No Life Poster Join Date: May 2006 Location: wordwide Age: 48
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | hi mr support mi phone i9505 no repair wifi Please Wait Enter Test Mode ... Enter Test Mode OK! Product ID: Unknown Not Support Current Hardware ! Total Time: 9.12 s br treo29 |
03-11-2014, 17:09 | #13 (permalink) |
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | Select The Proper Settings. Dial *#7284# and choose UART -> MODEM and Qualcom Setting DM+MODEM+ADB DIAL *#0808&# Select DM OVER UART and Click Repair 3G Network |
03-11-2014, 17:12 | #14 (permalink) |
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | same problem Please Wait Enter Test Mode ... Enter Test Mode OK! Product ID: Unknown Not Support Current Hardware ! Total Time: 9.1 s |
