12-19-2010, 13:10 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: BG, Sofia Age: 47
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | Problem with S5620 dead boot[SOLVED] PS: CPU BCM2151F0 ; Flash Samsing K5R4G1GACM |
12-19-2010, 13:12 | #2 (permalink) |
Banned Join Date: Jun 2007 Location: Samsung
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | if u have uart cable sure can repair all samsung s5620 must select box port then press repair boot and select region press write boot and connect phone uart cable when nearly come to over write boot press volume down + hold key and keep hand after over will in 5 sec phone goes to download mode then connect usb and write flash with boot B.R |
12-21-2010, 08:49 | #4 (permalink) |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | Hallo again SPTTEAM, Are you 100% sure about this phone, because i'll buy your box only for this phone and THIS functionality. I have cable but other boxes are not support this revision of s5620. That is reason for buying your box. Because of this i must be sure. Thank's. |
12-21-2010, 09:44 | #5 (permalink) |
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | i havent seen your phone but for now i nearly 200 phone here repaired and all without problem have done i think its also can be done and u need uart cable for this |
12-30-2010, 10:21 | #6 (permalink) |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | Hallo SPTTEAM me need your help again. A litle history: Version of phone before flashing i don't know. I flash that phone with UFS to chande language, but after flashing without boot phone hang and restarting in menus. After that i flash only boot with ver S5230XFIF2 again with UFS and then phone is dead. I try with all solutions free and not free (BCM downloader posted from you, UFS). Now i work with SPT box. When i repair boot on 5620 everything seems ok and the log is: Please Connect Cable and Hold Power On Key Wait for the BOOT signal ... Send the Download start signal ... Wait for the Download start ACK signal ... Preboot Downloading ... SDRAM Init OK. FlashLoader Downloading ... Updata Boot ... SEC_BOOT Download Success ! Boot Repair Success ! Total Time: 39.59 s On LCD appear "DOWNLOAD". After that i connect USB cable and this is log from flashing: Detect Phone Connect ... Connect Phone OK. Please Wait Burn Flash ... Updata BCM Boot ... Updata Boot2 Boot ... Updata Drom Dsp Boot ... Updata Patch Dsp Boot ... Updata Sysparm Dep Boot ... Updata Sysparm Ind Boot ... Updata NVRAM6 Boot ... Command Respond Error ! Total Time: 38.92 s I try also repair boot with your box and then flash with UFS but again no success. Please help me again Thanks. |
12-30-2010, 11:38 | #7 (permalink) |
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | u must use multiloader to write boot afrer repair boot no other box or spt can write after repair boot just multiloader can help you |
The Following User Says Thank You to SPTTEAM For This Useful Post: |
12-30-2010, 16:36 | #9 (permalink) |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | No - multiloader not help to me. I try with multiloader ver 5.62 and 5.64. By the way in processor lists no BCM2151 - i try with 2153 like as picture. Another idea? |
12-30-2010, 21:02 | #10 (permalink) |
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | after this error just press volume down + hold then connect uart its will go again download mode without repair boot then rewrite boot and flash with multiloader all will ok B.R |
12-30-2010, 22:17 | #11 (permalink) |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | I try like you say, but after this error phone is exit from download mode and hang - i mean computer is not "see" phone with SPT and with multiloader searching. Phone go to download mode ONLY if i bring out battery, place it and again Repair boot with SPT. |
12-31-2010, 12:42 | #12 (permalink) |
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | after repair boot and phone gone download just write boot with multiloader and if boot write complete and phone not powered just replug battery and press vol down + hold key and connect uart cable its must go again download mode then this time write full with multi and phone will fixed |
12-31-2010, 16:47 | #13 (permalink) |
12-31-2010, 17:13 | #14 (permalink) | |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | Quote:
double post sorry! Plz delete it | |
12-31-2010, 17:49 | #15 (permalink) | |
1. Repair boot (UART cable, with SPT, region XF) - phone: Download mode; 2. Download boot (USB cable, Multiloader, reg. XF) - phone: no reaction, download stop on boot2 file and give me error downloading; 3. Download boot (USB cable, Multiloader, reg. XF) - phone: turn off, downloading OK; After that no reaction on buttons, uart or usb cable - nothing, only repair boot and again 1, 2, 3 ...... infinite series. | |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
