03-10-2011, 11:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 45
Member: 93284 Status: Offline Thanks Meter: 202 | S3350 problem[ANSWERED] In instruction is: Procedure Of S3350,C3200,S3310I Read Unlock Code: * For Read Code need allready download LockCode Table. * Download At Support Any Firmware * Select Speed Usb * Select Flash file * Dont mark Erase Whole Flash * Press SPT MODE and press * to phone and connect usb * Wait Spt Read Out Unlock Code but in version 10.6.9 and 10.8.1 SPT MODE is inactive (see pict. below) later tried to flash 3 times and always proces stoped at 28% (see pict. below) finally flashed without problem with oryginal flasher. Am I doing something wrong? BR |
03-10-2011, 11:24 | #2 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | If SPT MODE is inactive this mean that you should use FACTORY MODE and this procedure . Procedure Of S3350,C3200,S3310I Direct Unlock/Imei: * Download At Support Patched Firmware * Select Speed Usb * Select Patch file * Dont mark Erase Whole Flash (This Need Mark Just For Full Flash) * Press write and press * to phone and connect usb * After Flash Over Power On Phone And Connect usb * Select Modem Port * Tick unlock or imei which u want do * Press Factory Mode. |
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
03-10-2011, 15:50 | #3 (permalink) | |
Banned Join Date: Jun 2007 Location: Samsung
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | Quote:
Select Bsy file XXSPT OR JVSPT Select CDS File From Spt support XX or JV files Select CSC File From Spt support XX or JV files Mark Erase Whole Flash Then Press write after complete can write imei or unlock which u want | |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
