S3550 Cant detect[SOLVED] Hi! I have a problem: I try to write Patch to a S3550 but the prog cant detects the phone. 1. i select usb 2. select file 3. press write 4. connect pone while pressing * and pwr on prog: Power Off Phone And Insert USB cable ... and then its freeze here till i disconnect the phone... Ive checked the drivers also. ( inside SPT folder there are bad drivers for it cause driver version is: 1.0.0.4 and it doesnt contain the phone's vid/pid - Vid_058b&Pid_0041) So Ive searched for version 1.0.0.6 wich contains it. Original downloader is working Any ideas? |
if freeze u must connect phone with press * and without battery when software say ebl boot loader plug battery |
Tried, but no ebl boot loader message |
must press write then connect phone without battery and pressed * to usb then when u see sw say Injecting EBL-Loader ... must connect battery |
Tried that.... But sw doesnt say injecting if i connect phone vis usb without battery it not goes to flash mode also device manager not detects it only with battery. Original downloader also needs battery, without battery cant turn into flash mode. |
here i test with and without battery both can go mode and find driver correct coz if with battery its froze mean have problem on ebl injection then without battery can pass ebl injection contact me on msn we check together B.R |
Now it works.... I think i had problems with the usb ports. Tried on another pc and went fine... But when i flash Patch V2 phone not turns on. With Patch V1 i got error that write failed Phone's firmware: s3550XXJC6 |
V1: Power Off Phone And Insert USB cable ... Connect Phone OK. Injecting EBL-Loader ... Injecting EBL Boot ... Flash ID:[ 008988B1 ] Please Wait Erasing BSY Flash ... Updata BSY ... Write Data Error ! Total Time: 299.1 s |
first file select v2 cds and csc select normal xx files then write complete with mark erase whole flash |
Thnx for helping!!! Worked XD |
