02-09-2011, 13:45 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Hungary Age: 40
Member: 132496 Status: Offline Thanks Meter: 34 | S3550 Cant detect[SOLVED] I have a problem: I try to write Patch to a S3550 but the prog cant detects the phone. 1. i select usb 2. select file 3. press write 4. connect pone while pressing * and pwr on prog: Power Off Phone And Insert USB cable ... and then its freeze here till i disconnect the phone... Ive checked the drivers also. ( inside SPT folder there are bad drivers for it cause driver version is: 1.0.0.4 and it doesnt contain the phone's vid/pid - Vid_058b&Pid_0041) So Ive searched for version 1.0.0.6 wich contains it. Original downloader is working Any ideas? |
02-09-2011, 18:59 | #4 (permalink) |
Banned Join Date: Jun 2007 Location: Samsung
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | must press write then connect phone without battery and pressed * to usb then when u see sw say Injecting EBL-Loader ... must connect battery |
02-10-2011, 10:56 | #5 (permalink) |
Member: 132496 Status: Offline Thanks Meter: 34 | Tried that.... But sw doesnt say injecting if i connect phone vis usb without battery it not goes to flash mode also device manager not detects it only with battery. Original downloader also needs battery, without battery cant turn into flash mode. |
02-10-2011, 12:14 | #6 (permalink) |
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | here i test with and without battery both can go mode and find driver correct coz if with battery its froze mean have problem on ebl injection then without battery can pass ebl injection contact me on msn we check together B.R |
02-10-2011, 18:08 | #7 (permalink) |
Member: 132496 Status: Offline Thanks Meter: 34 | Now it works.... I think i had problems with the usb ports. Tried on another pc and went fine... But when i flash Patch V2 phone not turns on. With Patch V1 i got error that write failed Phone's firmware: s3550XXJC6 |
02-10-2011, 18:18 | #8 (permalink) |
Member: 132496 Status: Offline Thanks Meter: 34 | V1: Power Off Phone And Insert USB cable ... Connect Phone OK. Injecting EBL-Loader ... Injecting EBL Boot ... Flash ID:[ 008988B1 ] Please Wait Erasing BSY Flash ... Updata BSY ... Write Data Error ! Total Time: 299.1 s |
Police Radar Detection | grape | Off Topic Zone | 8 | 02-19-2004 14:36 |
how do you solve no signal - 5110? | philipal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-29-2001 03:27 |
SOLVED THE FREEZE PROBLEM IN 8850!!!!! Please post below your observations.. | jsp_m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-14-2001 19:52 |
I CANT GET DEJAN TO WORK! | dario | Nokia Hardware & Hardware Repair | 1 | 01-27-2001 11:01 |
cant unlock CSI eeprom | Stryker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 08-20-2000 13:00 |
