01-25-2011, 12:39 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: INDIA
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | SIR PLEASE HELP ME FOR S3310i[ANSWERED] i just bought spt box and iam tring my first phone S3310i which has phone code but iam facing problem to connect this phone for flashing, tried as tool gives mssage "power off phone and connect usb cable" , also tried with pressing * key and ineserting usb cable but every time got answer.... Power Off Phone And Insert USB cable ... Phone Connect TimeOut ! Total Time: 24.31 s but there in one tab "factory mode" by this tab this phone detected in tool and readed the phone code but that code is wrong because shows incorrect password try again Please Wait Enter Test Mode ... Enter Test Mode OK! SW Ver: S3310iDDJG1/S3310iODDJG1 IMEI: 352308041199700 BTID: E8E5D6-3C4FBB Phone SN: RW7Z700098 Phone Lock Code: 26268100 Please Updata Phone With SPT Patch Flash File First ! Total Time: 10.54 s so please sir if i can flash this phone in this tool guide me how to connect this phone to tool?? |
01-25-2011, 17:54 | #2 (permalink) | |
Banned Join Date: Nov 2009 Location: Lima, Perú
Member: 1159099 Status: Offline Thanks Meter: 6,371 | Quote:
I Here All Instructions. Procedure Of S3350,C3200,S3310I Direct Unlock/Imei: * Download At Support Patched Firmware * Select Speed Usb * Select Patch file * Dont mark Erase Whole Flash (This Need Mark Just For Full Flash) * Press write and press * to phone and connect usb * After Flash Over Power On Phone And Connect usb * Select Modem Port * Tick unlock or imei which u want do * Press Factory Mode. See This. http://forum.gsmhosting.com/vbb/6816113-post6.html Br; XcachorroX | |
01-26-2011, 07:57 | #3 (permalink) | |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | Quote:
when i am connecting by this method i can see pink screen on display stays for 4-5 seconds then phone starts and comes on phone lock display. and i could not see any body flashed this phone, any screenshot or logfile on forum which help me http://i633.photobucket.com/albums/u...angbvk/spt.jpg | |
01-26-2011, 12:35 | #5 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | hi sir as you said i tried it again and again first click write then connect phone pressing * key on phone keypad but why i dont know, this is not working for me , but when pink screen appears on display it detects in computer as usb driver ,(not a specific driver) in this condition this is not accepting any driver from spt driver folder , why this is not detects as samsung modem ? as i said before this pink screen stays for 4-5 seconds only and after this phone starts if i connect phone, puting usb cable to power off phone it comes in charging mode and then i can see in device manager as a samsung mobile usb modem, but not connecting phone for flashing then what to do sir?? |
01-27-2011, 07:50 | #8 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | hi sir this i got another phone which have same phone lock problem and this phone also i could not connect ,so sir is there any guidance for me ? Please Wait Enter Test Mode ... Enter Test Mode OK! SW Ver: S3310iDDJG1/S3310iODDJG1 IMEI: 352308045902300 BTID: 101DC0-F6DF07 Phone SN: RWAZA97719 Phone Lock Code: 77777000 Please Updata Phone With SPT Patch Flash File First ! Total Time: 19.98 s |
01-27-2011, 09:40 | #9 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | hi sir now while it asking driver(usb driver) in pink screen i cacelled it and updated driver which is in device manager in yellow mark of phone, given path from spt folder S3550-C3200-S330i-Infineon after this phone detected as "FLASH LOADER UTILITY" but see the result ...... Power Off Phone And Insert USB cable ... Connect Phone OK. Injecting EBL-Loader ... Sync'ing to loader Failure ! Total Time: 26.37 s |
01-28-2011, 00:55 | #11 (permalink) |
Freak Poster Join Date: Apr 2010 Location: --------England------
Member: 1280788 Status: Offline Thanks Meter: 267 | Today i done 24 pcs working perfect just press star * key then insert the usb cable,and install the driver when driver installed.remove cable and bettery form phone and press the write and again press * key from phone and insert cable . i will work ... br |
02-03-2011, 09:42 | #14 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | hi sir this is really surprise to me that toay i got third one S3310i phone for "phone lock" and as i done the FACTORY MODE (as i tried same before) but this time the code which is readed by spt is worked for phone lock this is strage happened, now please SPTTEAM you have to answer me that why those two code which readed by spt was not worked also i am waiting for to solve my flashing problem Please Wait Enter Test Mode ... Enter Test Mode OK! SW Ver: S3310iDDJG1/S3310iODDJG1 IMEI: 352308044061190 BTID: D4E8B2-FA8E48 Phone SN: RW5Z949216 Phone Lock Code: 99305010 Please Updata Phone With SPT Patch Flash File First ! Total Time: 18.15 s |
02-03-2011, 12:23 | #15 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Even m facing the same problem .... even i wanted to unlock this fone ... here the logs of flashing Power Off Phone And Insert USB cable ... Connect Phone OK. Injecting EBL-Loader ... Sync'ing to loader Failure ! Total Time: 22.67 s |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
