10-09-2010, 11:53 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: india Age: 40
Member: 101117 Status: Offline Thanks Meter: 466 | 2120i restart flashed sucsesfully same restart position. in the end flashed CSC file with 2 main files set working ok now select model 2121b select 3 files E2120iDDJD6.cla E2120iDDJD6.tfs E2120iODDJD6.csc then write imei check in pic now set working absolutly fine check if it works for other membres too.... THANX |
The Following 10 Users Say Thank You to kailash_gm For This Useful Post: |
10-09-2010, 14:14 | #2 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 205738 Status: Offline Thanks Meter: 129 | Start NOR flash NOR flash - ok Start Flash TFS TFS flash - ok Start Flash CSC CSC format - ok CSC flash - ok Download - ok Elapsed time: 708 second, sw ver: 3.4.0064 ------------------------------------------------------------------------------- Selected model: E2121B Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 53 second, sw ver: 3.4.0064 ------------------------------------------------------------------------------- same thing i tried but not worked for me........need another solution wbr... |
10-09-2010, 16:13 | #4 (permalink) | |
Member: 101117 Status: Offline Thanks Meter: 466 | Quote:
so plz try erasing thn flash with 3 files | |
The Following User Says Thank You to kailash_gm For This Useful Post: |
10-09-2010, 16:18 | #5 (permalink) | |
i dont know is it right funda or not but many times i tried it worked for me just dissconnect from internet set speed to slow thn flash the phone......... while flashing dont open any application.. post result | |
The Following 3 Users Say Thank You to kailash_gm For This Useful Post: |
10-09-2010, 19:35 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: lucknow
Member: 275643 Status: Offline Thanks Meter: 360 | also one easy solution to reapir blink of samsung e2120i is that first u read any ok set flash file, and after that flash it with that file, i did it this and doing this set sucessfully. |
10-09-2010, 19:49 | #7 (permalink) | |
Freak Poster Join Date: Mar 2010
Member: 1263706 Status: Offline Thanks Meter: 31 | Quote:
With Factory flasher it works always.I have been reviving E2120i for a long time with factory flasher.This is good for all Z3x Owners..not listed in list but supports an another way. Gsm_Fone.. | |
The Following 2 Users Say Thank You to Gsm_Fone For This Useful Post: |
10-10-2010, 07:18 | #8 (permalink) |
Junior Member Join Date: Jun 2006
Member: 293509 Status: Offline Thanks Meter: 10 | Hope, there will be no more back job for you friend.... this model is a bit crazy...and a pain in the @$$...hehehe |
The Following User Says Thank You to mharl_striker For This Useful Post: |
10-13-2010, 11:03 | #11 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: tamilnadu,india
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | Quote:
The Following User Says Thank You to ChandruChiyyan For This Useful Post: |
10-18-2010, 03:11 | #14 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Tested and confirmed..!!! its Working really-, Code: Selected model: E2121B Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Start TFS format... OK Start NOR flash NOR flash - ok Start Flash TFS TFS flash - ok Start Flash CSC CSC format - ok CSC flash - ok Download - ok Elapsed time: 770 second, sw ver: 3.4.0068 Selected model: E2121B Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 61 second, sw ver: 3.4.0068 |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-01-2000 23:28 |
