02-12-2021, 12:42 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: pakistan
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | a305f u4 patch failed [Answered] Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Patch CERT Aug 2019 Selected model: SM-A305F Software version: 42.1 Waiting ADB device... OK Reading phone info... Model: SM-A305F Android version: 10 PDA version: A305FDDU4BTB3 CSC version: A305FODM4BTB3 Phone version: A305FXXU4BTA3 Product code: SM-A305FZKFINS CSC country code: India CSC sales code: INS Carrier ID: XSG Phone SN: RZ8M62XWKRN IMEI: ???????????? HW version: MP 0.200 RF cal date: 20190621 Chip name: EXYNOS7904 Modem board: SHANNON327 Security patch: 2020-02-01 Boot Warranty bit: 1 SIM State: LOADED,LOADED Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible. Done with Samsung Tool PRO v.42.1 |
02-12-2021, 13:42 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,085 | Hello. Reflash your phone to this firmware and repeat. https://sfirmware.com/ru/downloads-f...cusisoag86_fac |
The Following User Says Thank You to Z3X For This Useful Post: |
