11-16-2017, 19:12 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Barnsley UK Age: 56
Member: 7910 Status: Offline Thanks Meter: 57 | a520f read codes wicked Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-A520F Software version: 29.8 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM433 Reading phone info... OK Model: SM-A520F AP version: A520FXXU1APLL CSC version: A520FVFG1APLB CP version: A520FXXU1APLL Product code: SM-A520FZKAVOD Phone SN: R58J578K0LT Unique number: CBJ107F534D1934 Searching Samsung diag port... detected COM368 Reading phone info... OK CP version: A520FXXU1APLL CP build: Dec 25 2016 13:13:56 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 69082590 NET lock: 80264927 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.8 |
