Old 04-20-2021, 13:05   #1 (permalink)
Member: 25334
Thanks Meter: 2
A530F Read Codes via Server failed [Answered]
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will appear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
To read security codes using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, select 'Read codes ...' algo,
write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server [DIAG Jan 2021]
Selected model: SM-A530F
Software version: 42.10
Checking Login and Password... OK
Ballance: 32 crd.
You have 32 credit(s) left. This operation takes 5 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-A530F
Android version: 9
PDA version: A530FXXSGCUA1
CSC version: A530FOXMGCUA1
Phone version: A530FXXSGCUA3
Product code: SM2A530FZKASER
CSC country code: Russia
CSC sales code: SER
Carrier ID: PAN
Phone SN: R58K80XSK0R
IMEI: 355038096733440
HW version: REV0.3
RF cal date: 20180807
Chip name: EXYNOS7885
Modem board: SHANNON327
Security patch: 2021-01-01
Boot Warranty bit: 0
SIM State: ABSENT
Initialization zTool... OK
Running zTool, please wait... OK
Reading data from phone... OK
Searching Samsung diag port... detected COM17
Checking diag port... OK
Searching Samsung modem... detected COM16
Searching server... OK
Checking server answer... modem not supported
Done with Samsung Tool PRO v.42.10
Ballance: 32 crd.
Model: SM-A530F
Android version: 9
Phone version: A530FXXSGCUA1
CSC sales code: SER
Carrier ID: PAN
HW version: REV0.3
SIM State: ABSENT
Checking server answer... modem required
There is no information about this firmware on the server.
Old 04-20-2021, 13:09   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,058
Hello. Unfortunately, this bit not supported at this moment. Please wait for updates.
Page generated in 0.13383 seconds with 8 queries
