02-25-2009, 13:13 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Blang sir U890 unlock error.What can we do now? supported models: 53 andrew_tm 2008(c) Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK IMEI: 35921300319422-8 BlueTooth Address: 00:12:56:44:7A:BF Elapsed: 0 secs. Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK IMEI: 35921300319422-8 BlueTooth Address: 00:12:56:44:7A:BF Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM63 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... Error read nand page Elapsed: 46 secs. What can we do for this problem? |
02-25-2009, 13:47 | #2 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Sorry blang sir.Now its done.Thanks. Hai blang sir! I will try one more time.But now i will do first flash with this file U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK.After press unlock it will says insert accepted sim and phone will fully on then press ok.I will do what that option says.Atlast Unlock will be Done.Thank you one more time.Because Yesterday I will send you my problem.With in 24 hours you are solved my problem.I never saw this type of support.Iam not lieing.Just I will express my opinion.Any way You done a Good job.Thanks to Z3x Team. Here is the flash log: Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK IMEI: 35921300319422-8 BlueTooth Address: 00:12:56:44:7A:BF Elapsed: 1 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM63 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 99 secs. |
The Following User Says Thank You to caremobiles For This Useful Post: |
03-01-2009, 12:39 | #4 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 306678 Status: Offline Thanks Meter: 3 | Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM63 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... Error read nand pag When step2 you need insert TestSim and power on phone , this moment insert USB cable and in phone show logo boot , fast click OK , |
03-01-2009, 14:35 | #5 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=688659 Qualcomm update v. 1.3.4 -Added u890 direct unlock. U300, U310, U890, U880, U450, U900 Step by step manual: 1. Download needed firmware for your phone from folder "SPECIAL_FW_FOR_UNLOCK_U300_U310_U450_U880_U89 0_U9 00" from support area. 2. Flash phone. 3. Press unlock button. 4. If phone will show "no network" write NVM (c:\programm files\z3x\lg\lgq\nvm\) P.S. All firmware in SPECIAL_FW_FOR_UNLOCK_U300_U310_U450_U880_U890_U90 0 folder support 32Kb, 64Kb, 128Kb sim card NOTE: Which is the Version of U890? from UK and so on.? What is error after Isert sim you want to use after FLASH the phone? It has to be Sim Locked.(not Insert USIM) Enjoy. | |
11-13-2010, 11:25 | #6 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
Unlock is Done But No Network Found.................... Please Any One Give Nvm File Support for Z3x Box it's Very Urgent............. Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-IT IMEI: 35921300308728-1 BlueTooth Address: 00:12:56:43:EF:FF Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. --> (v.2.0.7) NV file: NV_U880_U890.nv2 NV File Version: 82 NV File Model: Y@9D NV Records: 2074 Corupted file! Elapsed: 0 secs. --> (v.2.0.7) | |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
11-13-2010, 12:05 | #7 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | When I Write U890_network_ok.cnv Yes Fund Network Thanks Z3x Team............. v.2.0.7 supported models: 145 andrew_tm 2010(c) Select ComPort or use Search Phone button! Elapsed: 0 secs. --> (v.2.0.7) Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-IT IMEI: 35921300308728-1 BlueTooth Address: 00:12:56:43:EF:FF Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. --> (v.2.0.7) NV file: U890_network_ok.cnv NV File Version: 1 NV File Model: U890 NV Records: 417 Write NV... Phone reboot! Elapsed: 5 secs. --> (v.2.0.7) Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-IT IMEI: 35921300336259-3 BlueTooth Address: 00:12:56:45:BDC Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. --> (v.2.0.7) Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM19 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 91 secs. --> (v.2.0.7) Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-IT IMEI: 35921300336259-3 BlueTooth Address: 00:12:56:45:BDC Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. --> (v.2.0.7) NV file: U890_network_ok.cnv NV File Version: 1 NV File Model: U890 NV Records: 417 Write NV... Phone reboot! Elapsed: 8 secs. --> (v.2.0.7) |
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
A637 Unlock error.What can I do for this? | caremobiles | Z3X-Team Products | 15 | 10-07-2013 13:21 |
N95 8gb Unlock error.What can I do? | caremobiles | Nokia Base Band 5 ( BB-5 ) | 7 | 04-07-2009 14:11 |
WHY WHEN WHAT CAN WE DO FOR E65 flashing BY UB???? | tsarkh | Universalbox | 0 | 08-08-2007 09:25 |
What can we do in service mode?? | bre786 | Infineon C16X M51 & ARM7 M52 BASED | 1 | 03-13-2006 12:37 |
What can we do if any MMC card not b unlock????? | MUNEEB_AKHTAR_RAZA | Various | 1 | 02-28-2006 09:13 |
