10-31-2009, 11:20 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2006
Member: 390492 Status: Offline Thanks Meter: 67 | Card Driver error in windows 7 all installed ok no problems the only problem is the Card driver its not compatible with windows 7 it finding the driver but says cant intall is there any solution to install it mr blanq ? best regards |
10-31-2009, 11:31 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
05-27-2010, 07:22 | #5 (permalink) |
Freak Poster Join Date: Nov 2009 Location: across in the archipelago
Member: 1170687 Status: Offline Thanks Meter: 30 | yup tested z3x not detected smartcard in z3x... Mr Blang Z3x users will be happy if you put egate shlumberger cards in Z3x support so that we can easily download it and enjoy using Z3x in window7... thanks |
05-27-2010, 07:36 | #7 (permalink) |
Freak Poster Join Date: Apr 2008 Location: balingasag misamis oriental ph
Member: 742460 Status: Offline Thanks Meter: 64 | it working for me i just make software compatible to windows xp change properties all software of z3x to compatible to windows xp just right click the software select properties the compativility includingt the z3x shell |
05-29-2010, 15:15 | #9 (permalink) |
Member: 390492 Status: Offline Thanks Meter: 67 | thanks to baba5031 i solved my problem ! just installed z3x on win 7 and worksss !! solution is very easy .. just update your shell to 3.4 then do update.. then done ! your z3x workss |
08-12-2010, 10:31 | #10 (permalink) | |
Junior Member Join Date: Jul 2006
Member: 314255 Status: Offline Thanks Meter: 5 | Quote:
please show your solution | |
Driver POTATO BOX Windows 7 64 bit | huyanten | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 06-16-2010 17:02 |
ub application window display problem in windows 7 how to correct please see | GSMaxx | Universalbox | 2 | 03-13-2010 10:40 |
UST2 Pro in Windows 7 sucess | Sethxp | UST Pro II | 1 | 12-04-2009 20:21 |
