12-18-2014, 11:39 | #511 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.7.7 ----------------------------------------------------------------------------------- To connect SGH-I527 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I337M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SGH-I337M Reading info... Mode: Normal Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Mar 1 2014 Firmware released time: 02:25:17 SW Version: M9615A-CEFWTAZM-4.0.17135 Send SPC... SPC send successfully Writing QCN... Wrting EFS... EFS write successfully Writing QCN done Writing QCN failed | |
12-18-2014, 15:18 | #513 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Turkey Age: 30
Member: 2041919 Status: Offline Sonork: 1111006 Thanks Meter: 88 | Install samsung tools 16.8 and make repair nvm, it will fix your problem Network_FIX_v1_z3x dowland Dowland Samsung Tools 16.8 |
The Following 2 Users Say Thank You to Özkaya For This Useful Post: |
12-18-2014, 23:21 | #522 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Your "unique" CERT must not be so unique. If it isn't working for MetroPCS then your seller jipped you. It's a brutal market out there with plenty of scammers. You should've asked for the IMEI of the CERT to make sure it was usable on Metro before getting it. |
The Following User Says Thank You to ecs87 For This Useful Post: |
12-18-2014, 23:30 | #524 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | When buying a .cert you need to verify a few things 1) is the seller legit 2) is the IMEI in the CERT blacklisted 3) Can the IMEI in the CERT be used on MetroPCS (you're going to need to contact MetroPCS most likely for this step) 4) will the seller sell your cert file to other people 5) are you OK with the seller selling your cert to other people |
