Old 12-18-2014, 11:39   #511 (permalink)
ahmertelecom's Avatar
Member: 210880
Sonork: 100.1577765
Thanks Meter: 151
Originally Posted by rasgula View Post
if you search you can find it easily but here you go.........its tested by me.
Welcome to Octoplus/Octopus Box Samsung software version 1.7.7
To connect SGH-I527 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
To connect SGH-I337M phone you have to perform the following steps:
13. Restart phone.
Platform: Samsung Android
Selected port: COM17
Selected model: SGH-I337M
Reading info...
Mode: Normal
Firmware compiled date: Dec 24 2013
Firmware compiled time: 00:00:00
Firmware released date: Mar 1 2014
Firmware released time: 02:25:17
SW Version: M9615A-CEFWTAZM-4.0.17135
Send SPC...
SPC send successfully
Writing QCN...
Wrting EFS...
EFS write successfully
Writing QCN done
Writing QCN failed
Old 12-18-2014, 14:52   #512 (permalink)
Member: 2169302
Thanks Meter: 51
Anybody with cert g357m share please
Old 12-18-2014, 15:18   #513 (permalink)
Özkaya's Avatar
Member: 2041919
Sonork: 1111006
Thanks Meter: 88
Originally Posted by bydetay View Post
i9506 2g network is fix best regard
Install samsung tools 16.8 and make repair nvm, it will fix your problem
Network_FIX_v1_z3x dowland
Dowland Samsung Tools 16.8
The Following 2 Users Say Thank You to Özkaya For This Useful Post:
Old 12-18-2014, 17:26   #514 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
N8020 qcn wanted
N8020 qcn wanted pls help URGENT~
Old 12-18-2014, 19:38   #515 (permalink)
Member: 2168814
please help
Please I need cert for sm-g800f, please help , tried to find on all gsmhosting but seem's nobody uploaded it, thanks, please people with good soul
Old 12-18-2014, 21:48   #516 (permalink)
darkside85's Avatar
Member: 2033258
Thanks Meter: 61
Originally Posted by John(LMT) View Post
T399N Metro PCS Certificate needed please, thanks in advance!
T399N MPCS.im looking for the same cert. please guys help i have a few good links that are here in the forum with most of the cert relesead here.
so i can save you a lil more time
Old 12-18-2014, 21:49   #517 (permalink)
Member: 2310348
Thanks Meter: 2
Is there any way to make g900t work on MetroPCS?
Old 12-18-2014, 22:23   #518 (permalink)
Member: 2076039
Thanks Meter: 648
Yes but you'll need a CERT that no one else is using. Basically you're going to end up buying a CERT or having access to a database of CERTs.
Old 12-18-2014, 22:25   #519 (permalink)
Member: 2310348
Thanks Meter: 2
Okay so if I have a unique cert and I use it how come it doesn't work?
Old 12-18-2014, 22:43   #520 (permalink)
Member: 2051424
Thanks Meter: 16
How do you konw it is unique?
Old 12-18-2014, 22:46   #521 (permalink)
Member: 2310348
Thanks Meter: 2
I bought from overseas
Old 12-18-2014, 23:21   #522 (permalink)
Member: 2076039
Thanks Meter: 648
Your "unique" CERT must not be so unique. If it isn't working for MetroPCS then your seller jipped you. It's a brutal market out there with plenty of scammers. You should've asked for the IMEI of the CERT to make sure it was usable on Metro before getting it.
The Following User Says Thank You to ecs87 For This Useful Post:
Old 12-18-2014, 23:22   #523 (permalink)
Member: 2310348
Thanks Meter: 2
Ah okay I see. So I need to verify with MetroPCS first correct?
Old 12-18-2014, 23:30   #524 (permalink)
Member: 2076039
Thanks Meter: 648
When buying a .cert you need to verify a few things
1) is the seller legit
2) is the IMEI in the CERT blacklisted
3) Can the IMEI in the CERT be used on MetroPCS (you're going to need to contact MetroPCS most likely for this step)
4) will the seller sell your cert file to other people
5) are you OK with the seller selling your cert to other people
Old 12-18-2014, 23:32   #525 (permalink)
Member: 2310348
Thanks Meter: 2
Very helpful. By any chance where can I have find legit sellers?
Page generated in 0.23557 seconds with 9 queries
