12-05-2014, 20:52 | #407 (permalink) |
Junior Member Join Date: Dec 2007
Member: 655586 Status: Offline Thanks Meter: 11 | i tried blocking one connector of battery and then doing it still on one port it freezes at reading. and other port it says successful after doing tons of things. but still at the end imei and all files are there.so i donot know what i am doing wrong Can some one let me know. |
12-06-2014, 10:39 | #411 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
12-06-2014, 13:36 | #412 (permalink) | |
Insane Poster Join Date: Sep 2013 Location: Syria, Idleb Age: 31
Member: 2019489 Status: Offline Thanks Meter: 57 | Quote:
- support SM-G900H read / write CERT - support SM-G9006V write CERT - support SM-G9006W write CERT - support SM-G9008V write CERT - support SM-G9008W write CERT - support SM-G9009D write CERT - support SM-G9009W write CERT - support SM-G900A write CERT - support SM-G900AZ write CERT - support SM-G900F write CERT - support SM-G900FD write CERT - support SM-G900FQ write CERT - support SM-G900I write CERT - support SM-G900K write CERT - support SM-G900L write CERT - support SM-G900M write CERT - support SM-G900P write CERT - support SM-G900R4 write CERT - support SM-G900S write CERT - support SM-G900T write CERT - support SM-G900T1 write CERT - support SM-G900V write CERT - support SM-G900W8 write CERT - support SM-N910K read / write CERT - support SM-N910L read / write CERT - support SM-N910S read / write CERT - support SM-N910U read / write CERT - support SM-N910A write CERT - support SM-N910F write CERT - support SM-N910G write CERT - support SM-N910P write CERT - support SM-N910R4 write CERT - support SM-N910T write CERT - support SM-N910W8 write CERT | |
The Following User Says Thank You to en.osama For This Useful Post: |
12-06-2014, 14:14 | #416 (permalink) |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | Successfully fixed the following models: G900W8 ---> using the cert file via z3x G870 ----> S5 Active N900xx -----> Note 3 models N910W8 ---> using the cert file via z3x All models require that the efs to be resetted before performing the cert flashing. If all done correctly its a process which shouldn't take more than 5 minutes. Remember - Root is required to perform these functions... Yes I have certs which I used to fix the phones... yes they work... sorry cannot share them so please do not ask..... |
