01-15-2018, 00:27 | #1 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2799920 Status: Offline Thanks Meter: 2 | Can't remove FRP lock. Flashed and installed firmware, and the message is still there I flashed the S7 (using tnt enforce + Z3X 24.3 Loader + SamsungToolPRO + Combination file) and did a factory reset while being in factory binary mode, After that, I installed a hardware (G930FXXU1DQJ3) with odin. Everything works but the message is still there. Of course I know that if ן got the mail/ password/ receipt but unfortunately I don't have any of those. I've tried the bypass on the "sticky" thread but it doesn't work. Any suggestions please?... |
01-15-2018, 00:47 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Can u able to share here screen of recovery.?Second thing, why u used old Z3x Ver.24.3 ? Which combination file u used.? And did u try to Enable OEM & reset phone after flash combination/ or remove FRP/deactivation lock wit z3x ? |
The Following User Says Thank You to -Mosin- For This Useful Post: |
01-15-2018, 01:26 | #3 (permalink) |
Member: 2799920 Status: Offline Thanks Meter: 2 | Hi, thanks for helping. 1. Screen of recovery meaning the screen I get when I press Home+Power+Volume up? 2. Used that Ver. because I was following a tutorial and that was the version they used there. 3. The combination file named "COMBINATION_FA60_G930FXXU1API2_CL7964511_QB110372 33_REV00_user_mid_noship" . tar 4 .After I flashed, the S7 got in "Factory binary mode", then I did a factory reset and when it was done, I pressed "Reboot to flash". After that I installed the hardware. 5 ."did u try to Enable OEM & reset phone after flash combination/ or remove FRP/deactivation lock wit z3x" - I don't know how to do any of this, If I could get a link to a video it will be great. Thanks! Last edited by Maoradm; 01-15-2018 at 01:35. |
01-15-2018, 04:04 | #4 (permalink) |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | As simply as this: 1. Flash to stock bit 1 2. Flash this file---> https://mega.nz/#!tYoW0AqC!eT3MnJLpY...i8i-OPqPZXif20 3. Wait until the phone boots up, adb drivers will be installed, open cmd.exe and--> "adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1" 3.1 Or more easy, open z3x, select g930f and do FRP RESET, agree to EULA bla bla and done, bypass activation wizard, enable OEM UNLOCK and do FACTORY RESET/WIPE DATA from menu. In case wizard still there, go back to the initial screen of WELCOME and do this --> "adb shell am force-stop com.sec.android.app.setupwizard" No complications, no complex steps. Please report back, and remember the basics, FRP removal is just based on enabling adb, and how do you acomplish that? With eng-roots or boots/sboots from combinations. |
The Following 3 Users Say Thank You to Prsctt For This Useful Post: |
01-16-2018, 00:43 | #5 (permalink) |
Member: 2799920 Status: Offline Thanks Meter: 2 | Thanks for helping man... 1 . Unfortunately, I don't know what is "stock bit 1", so I can't flash to it... could you please send a link to a stock bit 1 file to flash to ? 2 . Can I make the rest of the steps without flashing to stock bit 1, meaning to flash only with the file that you send me and moving to the cmd ? (For a case I wont find the file). 3 . As for the second, easier solution: I'v download z3x ver 28 2, but I still don't have g 930 f in the list of models. Do you know what version of z3x have a G930F on the list? Thanks everyone ! |
01-16-2018, 03:43 | #6 (permalink) |
Member: 2799920 Status: Offline Thanks Meter: 2 | Hi, I just figured out that by "stock bit 1", you meant I should flash to firmware and I did. It's already the one I used before. After that I flashed with your combination file but after the flash I don't get the factory binary mode screen, but only a black screen with "Samsung" logo stuck on it. I flashed again with the combination file I had and I got the binary mode, and installed the hardware again. but I'm still at the same point with the FRP lock. Can I use the command you gave me while using the combination file I have and looks to work fine? (adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1) ? |
01-16-2018, 03:52 | #7 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2110911 Status: Offline Thanks Meter: 22 | You are on z3x forum so i supposed you have z3x, solution is easy, flash any stock rom and remove frp using micro uart cable, if you dont have z3x with activation pro then you could flash any firmware and remove frp using one of many manual methods avaliable, this could be a phone call, using BT hands-free, quick short cut, etc. |
01-16-2018, 04:13 | #8 (permalink) |
Member: 2799920 Status: Offline Thanks Meter: 2 | Update: I couldn't wait for an answer so I flashed with the combination file I had. after the flashing, the factory binary started - and then I typed the command. The "cmd" didn't respond with an error or something so I guess the phone got the command, but the FRP is still there after installing the hardware... what else can I do ? As for me being in a z3x forum, I'm sorry to bother you, I initially posted on S7 forum, but they moved it here. Anyway..Iv'e tried each of the methods you reminded with no luck. When searching the web, I found out I'm not the only one having troubles with the former old methods ... |
01-16-2018, 04:28 | #9 (permalink) |
Member: 2799920 Status: Offline Thanks Meter: 2 | Flashing and Installing a new hardware does not solve the problem. tried it many time, as well as all the manual methods yo mentioned. I initially posted on S7 forum, but they moved it here. Anyway..Iv'e tried each of the methods you reminded with no luck. When searching the web, I found out I'm not the only one having troubles with the former old methods ... Update: I couldn't wait for an answer so I flashed with the combination file I had. after the flashing, the factory binary started - and then I typed the command. The "cmd" didn't respond with an error or something so I guess the phone got the command, but the FRP is still there after installing the hardware... what else can I do ? |
01-16-2018, 07:36 | #10 (permalink) |
Member: 2107306 Status: Offline Thanks Meter: 612 | My man: 1. FLash to stock QD2--> post here compilation you flashed, IT NEEDS TO BE QD2 IN ORDER TO AVOID BOOT-LOOPS. 2. Flash engroot I've shared. 3. User RESET FRP option on z3x, agree to the EULA bla bla and a message like this will appear--> "Waiting for adb device: OK" 3.1 A series of data of your phone and at the end something like this--> "For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' " There's nothing to it, I've done it a hundred times on this model. Please replay. PD: Do not flash more entire combinations, you are wasting your time. |
01-16-2018, 10:06 | #11 (permalink) |
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Simple way to remove Frp from this phone is UFS Method.Just write back Stock firmware and remove frp by UART cable.UFS METHOD Doesn’t Need any Modification or combination in firmware. |
01-16-2018, 21:24 | #12 (permalink) | |
Member: 2799920 Status: Offline Thanks Meter: 2 | Quote:
1 . FLash to stock QD2-- this "stock DQ2" file... is this the file you sheared? I thought it was another one, so I downloaded another file, but they're named the same : "G930F_ENG_ROOT_B1_QD2_7 . 0" (the size is a little different). If the meaning is not to your file, could link me to a good one please? (I don't know if what I've downloaded is fine). 2 . Flash engroot I've shared. - Meaning I should use 2 files totally? First the "stock DQ2", and then the file you sheared? because your file itself is already "ENG_ROOT_B1_QD2" so I'm a bit confused... I've tried to follow your steps anyway, to my best understanding: I Flashed to stock QD2 using Z3X- I used a file I downloaded named "G930F_ENG_ROOT_B1_QD2_7 . 0" - I got a bootloop. I pressed "Reset to flash", and while being on download mode, I flashed with the file you sheared. I got a bootloop again... what seems to be the problem ? | |
01-17-2018, 02:43 | #13 (permalink) |
Member: 2107306 Status: Offline Thanks Meter: 612 | OK, flash to stock means a whole firmware. This firmware for ex--> G930FXXS1DQD2_G930FTMS1DQD2.zip To be honest, I can't find any QD2 firmware for G930F but all you need to do is search. If you can't find anything, try this site---> https://www.theandroidsoul.com/samsu...y-s7-firmware/ and flash something close to QD2 in security patch. For ex--> G930FXXS1DQHM_G930FPNG1DQEF_PNG.zip After that, flash the file I shared with you. That's the engroot that allows you to enable ADB and later remove FRP. Please post back with results. |
01-17-2018, 05:28 | #14 (permalink) |
Member: 2799920 Status: Offline Thanks Meter: 2 | Thank you very much man ! what finally worked: 1 . I flashed to a firmware withe this security patch G 9 3 0 F X X U 1 D Q B 7 2 . flashed to the file you shared - then when the phone botted - i entered the command line in cmd. 3 . I went to download mode again and flashed the latest hardware in my language... work's like a charm- much thanks to everyone who tried to help and a big one to you Prsctt. |
02-19-2018, 11:32 | #15 (permalink) |
Freak Poster Join Date: Feb 2004
Member: 55142 Status: Offline Thanks Meter: 6 | hi, after flashing combination file and reset FRP all semms ok but FRP is still ON !!! factory reset is also done Operation: Reset FRP Selected model: SM-G930F Selected port: COM10 USB Serial Port Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZSA Phone version: G930FXXU2ARA1 PDA version: FA60_G930FXXU2ARA2 CSC version: CSC country code: CSC sales code: HW version: MP 0.700 Phone SN: R58HA2TK8CA Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2016-01-01 RF cal date: 20161015 IMEI: 35843907xxxxx Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.8 can someone help? |
