Old 06-28-2011, 00:24   #301 (permalink)
Member: 455057
Thanks Meter: 2
what is pcb whith samsung
The Following User Says Thank You to lamp08 For This Useful Post:
Old 07-03-2011, 11:49   #302 (permalink)
debapra_gsm's Avatar
Member: 1247853
Thanks Meter: 71
IT IS A DEAD THREAD...........SO PLZZZZZZZZZZZ STOP POSTING....
SIMPLE SOLUTION...JUST SAY SERVICE RATE TO YOUR COUSTOMERS & TELL ITS NO WARRENTY JOB.........IF IT WILL BACK AGAIN....AGAIN RATE applicable.....SIMPLE...SOLUTION..U KNOW WHY ?????? ITS PCB & SOFTWARE FOULT U CANT SOLVE permanently......
Old 07-07-2011, 16:03   #303 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Thanks Meter: 693
PCB is the Whole Phone without LCD and if u have a PCB in this case you do not need Z3x-box,ok?because is hardware problem!!!
Old 07-07-2011, 16:27   #304 (permalink)
hamidumz's Avatar
Member: 537854
Sonork: 100.1605784
Thanks Meter: 22
I had several E2120 that with heat on cpu was true
Old 07-21-2011, 19:58   #305 (permalink)
Member: 210936
Thanks Meter: 5
HI
I just rewrite imei and serial than i flash it with E2120DXIH5 and it's OK.
I hope I helped.
Old 07-22-2011, 08:06   #306 (permalink)
kapilpanday's Avatar
Member: 951882
Thanks Meter: 323
any hardwer / softwer solustion...................
Old 07-24-2011, 05:59   #307 (permalink)
Member: 638695
Thanks Meter: 10
nice soltion when change pcb then no need z3x
Old 07-25-2011, 14:22   #308 (permalink)
Member: 225934
Thanks Meter: 2
write this fullflash хттп://zalil.r_u/29947121 as a (bin,cla) and maybe it will help you, but for a couple a days. In the future everything will be repeated))) Topicstarter is correct.
Old 07-26-2011, 05:16   #309 (permalink)
aitta7130's Avatar
Member: 320655
Thanks Meter: 28
flash with hwk 100% problem solved
The Following User Says Thank You to aitta7130 For This Useful Post:
Old 07-30-2011, 13:54   #310 (permalink)
sakabeloha's Avatar
Member: 32403
Thanks Meter: 139
change the graphic card of lcd,rebuild PCB,after contact ur resseller,100% tested
Old 07-30-2011, 14:00   #311 (permalink)
sakabeloha's Avatar
Member: 32403
Thanks Meter: 139
last news:CLOSE TOPIC!!!!!
Old 08-04-2011, 10:39   #312 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
some times do not post failure while there is solution, sometimes if you flash with HWK phone revival , i solvem many phone through HWK. even on 5212i and 3212i in which sometimes z3x fail to repair, any way keep update to remove this error of fail to flash second eprom
Old 09-02-2011, 08:12   #313 (permalink)
Crazy Poster
Member: 776905
Thanks Meter: 2
Logics make you think right that changing pcb is like buying a new phone.braineess where are you guys?
Old 09-03-2011, 14:56   #314 (permalink)
NizamSLM's Avatar
Member: 223302
Thanks Meter: 27
Thanks keep it up.thank you.
Old 09-03-2011, 15:00   #315 (permalink)
Member: 255072
Thanks Meter: 46
use garua original downloader full erase then reflash many sets are have same problem
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Pic Solution jan Nokia Hardware & Hardware Repair 8 10-11-2010 10:56
100% unlock1 for Nokia 6150 v5.17 ------,......... cIVIc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-10-1999 02:00
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.20798 seconds with 10 queries
