02-24-2010, 17:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PILIPINAS
Member: 759375 Status: Offline Sonork: www.GSMPIONEER.com Thanks Meter: 895 | E2120 freeze... SOLVED by flashing here's is another download link http://www.4shared.com/file/22857497...tedbySHOX.html Code: Selected model: E2120 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Phone IMEI -> 00000000000000 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]: [SIM LOCK]: [PHONE LOCK]: [SP LOCK]: Read Info - ok Elapsed time: 30 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- Selected model: E2120 Selected com port: COM4 Selected speed port: 921600 Download - ok Elapsed time: 0 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- Selected model: E2120 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK NAND format - îę Start NOR flash NOR flash - ok Start Flash TFS Download - ok Elapsed time: 709 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- Selected model: E2120 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 48 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- |
The Following 3 Users Say Thank You to snakebreeder For This Useful Post: |
02-25-2010, 02:39 | #3 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 315550 Status: Offline Thanks Meter: 110 | what?????????????????????????????????? flashing is the good move.................... direct unlock wont work.............................................. ........ tried and tested 2pcs here direct unlock but still Blinking..... |
The Following User Says Thank You to dmaetrey For This Useful Post: |
02-25-2010, 08:52 | #4 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Quote:
http://forum.gsmhosting.com/vbb/show...&postcount=565 Br UMER | |
03-03-2010, 18:21 | #6 (permalink) | |
Member: 759375 Status: Offline Sonork: www.GSMPIONEER.com Thanks Meter: 895 | Quote:
and there are also phones that is freezed because of a full memory or corrupted operating files etc.... ----- now can you unlock a phone with corrupted OPERATING SYSTEM OR FILES? sometimes perhaps... right... SO DON'T pretend to be perfect and KNOW everything... i think in this field you can understand my point if you have a good I.Q...... THAT NOT ALL PROBLEMS HAVE THE SAME SOLUTION my friend... before you assume that... REMEMBER THAT not all problems are solved with the same ACTION... i shall give you an example... there are two pieces of let's say N73 unit.. both have black screen.. but not both of them can be repaird by LCD.. not both of them can be repaired just by display IC.. not both of them are OMAP faulty... NOW, do i have to ELABORATE it more to you? INSTEAD OF Criticizing others REPORT... (which we are not paid to do) JUST read.... if you need the IDEA then use it.. if you don't need it.. then ignore it... no one is forcing you to believe this.. but maybe sometime you will encounter the same problem and you can't solve just by unlocking ... maybe then you will believe no regards | |
The Following User Says Thank You to snakebreeder For This Useful Post: |
03-07-2010, 04:44 | #7 (permalink) |
Freak Poster Join Date: Jul 2007 Location: soon mars colony 2050 Age: 41
Member: 552857 Status: Offline Thanks Meter: 19 | Fresh from wasp s1 store z3x box... First try full flashing samsung e2120 walang sablay....freeze phone done the best z3x box ever i love this box buy na poh sila...................sulit po talaga............... |
The Following User Says Thank You to natemace For This Useful Post: |
07-12-2010, 14:26 | #9 (permalink) |
Freak Poster Join Date: Jun 2010 Location: morocco
Member: 1322811 Status: Offline Thanks Meter: 46 | hello no ned to flash phone just derict unlock worked100/100 using changin speedd 115200 her is log Selected model: E2120 Selected com port: COM3 Selected speed port: 115200 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 222 second, sw ver: 3.4.0058 |
10-29-2011, 20:43 | #13 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Lahore Pakistan. Age: 38
Member: 1284347 Status: Offline Sonork: 100.1592292 Thanks Meter: 977 | E2120 blinking solution use ufs 1st flash than check imei is 0000000000 write e2p file imei is ok ur problem will b solve br, am_gsm_cell...:::awais.as:::... |
12-20-2011, 14:08 | #14 (permalink) |
Insane Poster Join Date: Mar 2011 Location: Nigeria
Member: 1537420 Status: Offline Sonork: 100.1653338 Thanks Meter: 7 | I did one E2120 phone freeze with hwk today.It was very simple.I just click on unlock E2P.After that I inserted a sim card on my phone,switched it on and typed the master code provided by my hwk.My phone was unlocked but the imei was corrupt.So I clicked on rebuild imei,typed the original imei from the phone into the box provided and bingo...Phone is back to normal condition.Thanx for the contributions from fellow members in this forum. |
06-07-2012, 14:29 | #15 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Ahmedabad
Member: 320205 Status: Offline Thanks Meter: 181 | 10000000 % work no need flash Selected model: E2120 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 46 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Thanks sarji |
e2120, can i get flash with spanish | layna | NSPRO | 1 | 09-23-2010 21:08 |
C510 no network problem solved by flashing in just 200sec with setool:0 | sahil2000ind | SETool2 | 1 | 07-23-2010 04:44 |
MX Software Freezing[SOLVED by USER] | curtisbcm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-04-2010 06:19 |
e2120 free unlock by code | compermise | SWIFT Platform | 5 | 01-28-2010 18:50 |
se k850 no lcd problem solved by flashing with cruiser A2 flasher | adreesas | Cruiser Suite | 2 | 12-23-2009 20:20 |
