03-11-2019, 18:36 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bamako Mali
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | E2121B unlock problems I tried both E210+usb and j750 But always ERROR UNLOCK INSTRUCTIONS: Phone must be powered off! 1. Select correct COM port in 'Port' options. 2. Select connection mode in options ('Flash Mode' or 'TAT Mode') . 3. Press 'Unlock' for direct unlock. 4. Press 'Read Codes' to read security codes. 5. - Flash Mode: Connect the phone to selected port with UART cable and press 'Power' button shortly, or just insert cable to phone if you are using auto-ignition cable . (If you have connection problem, try to push 'Power' button while loader will be sent.) - TAT Mode: Connect the phone to selected port with UART cable and press 'Power' button about 3 seconds, or just insert cable to phone if you are using auto-ignition cable . Operation: Unlock Selected model: GT-E2121B Selected port: COM4 Z3X BOX Serial Port, 115200 Software version: 34.11 Connect phone and press power button... Phone detected Switching phone to TAT mode... OK Reading phone info... error On flash mode log UNLOCK INSTRUCTIONS: Phone must be powered off! 1. Select correct COM port in 'Port' options. 2. Select connection mode in options ('Flash Mode' or 'TAT Mode') . 3. Press 'Unlock' for direct unlock. 4. Press 'Read Codes' to read security codes. 5. - Flash Mode: Connect the phone to selected port with UART cable and press 'Power' button shortly, or just insert cable to phone if you are using auto-ignition cable . (If you have connection problem, try to push 'Power' button while loader will be sent.) - TAT Mode: Connect the phone to selected port with UART cable and press 'Power' button about 3 seconds, or just insert cable to phone if you are using auto-ignition cable . Operation: Unlock Selected model: GT-E2121B Selected port: COM4 Z3X BOX Serial Port, 115200 Software version: 34.11 Connect phone, press power button Waiting phone... OK Sending PRELOADER... error (2) Thank to all |
