10-09-2018, 13:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | Emegency call Activate Diagnostic Port: 1. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 2. Select device in ADB settings. 3. Press 'Activate Diag' button. Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Select device in ADB settings. 10. Fill values what you need to repair. 11. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Activate DIAG Selected model: SM-N7502 Selected port: COM8 Z3X BOX Serial Port Software version: 33.8 Waiting ADB device... OK Reading phone info... Model: SM-N7505 Android version: 4.4.2 PDA version: N7505XXUCNH1 CSC version: N7505OJVCNH2 Phone version: N7505XXUCNG2 Product code: Not Active CSC country code: UAE CSC sales code: XSG Phone SN: 00000000000 IMEI: 352832063140933 HW version: REV__ RF cal date: Unknown Chip name: EXYNOS5260 Modem board: XMM7160 Boot Warranty bit: 1 Incorrect model selected. This may damage your phone. Continue? Yes Activating DIAG... OK Activation DIAG done Done with Samsung Tool PRO v.33.8 |
