08-17-2016, 15:34 | #1 (permalink) |
Insane Poster Join Date: Aug 2014
Member: 2249474 Status: Offline Thanks Meter: 0 | FRP g935F ERRoR Selected model: SM-G935F Software version: 26.4 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM6 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... time out Phone not found Done with Samsung Tool PRO v.26.4 how can i fixen |
08-18-2016, 16:21 | #3 (permalink) | |
Insane Poster Join Date: Apr 2008 Location: Maroc
Member: 748202 Status: Offline Thanks Meter: 9 | Quote:
08-22-2016, 15:04 | #4 (permalink) |
Junior Member Join Date: Sep 2009 Location: lebanon
Member: 1116838 Status: Offline Sonork: 1122 Thanks Meter: 10 | hello i have the same problem Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM18 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... time out Phone not found Done with Samsung Tool PRO v.26.4 |
08-26-2016, 19:31 | #7 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1279165 Status: Offline Thanks Meter: 1 | I have found the time not to be too short, the application stops windows detecting the device, i killed Samsung Tool Pro while waiting maybe 20 seconds and the device is detected but as long as it is running it will not detect the device, very strange behaviour indeed. Windows 10 64Bit Samsung Tool Pro 26.5 |
08-26-2016, 19:44 | #8 (permalink) |
Member: 1279165 Status: Offline Thanks Meter: 1 | Edit to above, the script is stopping windows detecting new USB connections for any device, as soon as the script has ended it will start detecting USB devices again, why is this script freezing the USB stack? This is the issue that needs addressing. |
The Following User Says Thank You to hydrouk For This Useful Post: |
09-02-2016, 22:49 | #11 (permalink) |
Member: 748202 Status: Offline Thanks Meter: 9 | Solution: 1. After phone boot up adb should be enabled, put this command in adb shell: content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 2. Enable "OEM Unlock" in settings. Bye Bye FRP 3. Flash orig boot from Z3x Recovery folder. That's all. |
