11-02-2020, 10:33 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: canary island Age: 45
Member: 93421 Status: Offline Thanks Meter: 19 | For FRP to a Samsung with Combination, which arvhics do I use next? [Solved] Before I only had to select these files and that was it: system + sboot + boot + recovery + cache But now I have many more files and I don't know which ones I have to leave, I have tried various combinations but they end up giving security errors or improper flashing when they turn on (not during the flash itself). Can someone enlighten me please? |
11-02-2020, 10:41 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Hello. Flash full combination, then check in developer menu oem unlock option. 1. If oem unlock avaible, just enable it, then do reset via menu and flash full firmware. 2. If oem unlock not avaible, try flash firmware without userdata and cashe, after phone boots to recovery choose reboot system now, then wait until it boots to menu and make reset. Sometimes need to find firmware according to combination if phone dont starts (binary mixed up or some other errors or stucking on logo). |
The Following User Says Thank You to Z3X For This Useful Post: |
11-02-2020, 13:41 | #3 (permalink) |
Member: 93421 Status: Offline Thanks Meter: 19 | In this case, as in some others, the OEM menu does not appear, so I was asking, ok, I will try to do it without Cache and without USERDATa and to see how it is, I will comment, thank you very much for your quick response ^^ |
11-04-2020, 11:12 | #6 (permalink) |
Member: 93421 Status: Offline Thanks Meter: 19 | I try with J610FN I have Samsung J610FN. Combination works but dont have OEM option. when i try use stock firmware whitout USER DATA and CACHE falsh OK but later error: error of mixed up |
