05-21-2015, 17:26 | #1 (permalink) |
Crazy Poster Join Date: Jan 2014
Member: 2109210 Status: Offline Sonork: 100.1668991 Thanks Meter: 3 | Guide Direct Unlock sprint Galaxy S4/S5 log Operation: Unlock Selected model: SPH-L720 Software version: 21.0 Reading phone info... Reading IMEI... OK IMEI: 990003487765444 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.0 |
The Following User Says Thank You to Mercedesrainier For This Useful Post: |
05-21-2015, 23:09 | #2 (permalink) |
Member: 2109210 Status: Offline Sonork: 100.1668991 Thanks Meter: 3 | also works on other variants UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N900V Selected port: COM97 SAMSUNG Mobile USB Serial Port , Software version: 21.0 Reading phone info... Reading IMEI... OK IMEI: 990004662318504 Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.0 |
05-22-2015, 02:25 | #3 (permalink) | |
Member: 2109210 Status: Offline Sonork: 100.1668991 Thanks Meter: 3 | Quote:
log | |
05-22-2015, 07:19 | #6 (permalink) |
Freak Poster Join Date: Dec 2012 Location: The North
Member: 1861077 Status: Offline Thanks Meter: 89 | N915P Sprint I tried this method on N915P it failed why? I don't know the MSL/SPC Code for N915P, and it is not 000000, because all zeroes are by default for Verizon phones, and you don't need to unlock Verizon as they come unlocked. Now back to my Note Edge from Sprint, I used DFS many years ago and also CDMA workshop however, I don't have either of them a PRO version. So, I used the password and phone is unlocked but to fully unlock you must send SPC/MSL also. Since I don't have that not useful. Tried many methods by rooting the phone and try using terminal and command as getprop ril.MSL. Failed. Tried to use alogcat and got nothing. Z3X Pro 21.1 it fails bypass security.... error OCTO.. does it unlock and says unlock but actually still locked. Sorry bro no luck for me. Hope to hear others if they could do it. |
05-22-2015, 14:17 | #7 (permalink) | |
06-22-2015, 23:15 | #13 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | The same process as the Note 3s and S4s including the L720T (though it only throws 3G). Keep in mind that the L600 Galaxy Mega only throws 3G as well, you made need assistance for the Data Connectivity, a lot can unlock it domestically...haven't seen many users find a way to get the data going. It's possible though, trust me |
06-22-2015, 23:17 | #14 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | Quote:
We need to downgrade modem as well? What settings do we change in the hidden menu? Sent from my iPhone using Tapatalk | |
06-22-2015, 23:18 | #15 (permalink) |
Member: 2273678 Status: Offline Thanks Meter: 293 | Not necessarily, though if you do get a 4.4.2 then yes you will need the previous modem partition to be flashed onto the phone. Even if you do access the hidden menu, as soon as it throws you to apn...cannot be edited |
The Following User Says Thank You to F_X For This Useful Post: |
