12-04-2016, 20:32 | #3 (permalink) |
Major Poster Join Date: Aug 2014
Member: 2235849 Status: Offline Thanks Meter: 4 | sorry for being vague, i should be asking the process for imei repair for this model. i pressed repair button with imei box filled, and now my imei is all zeros although it says successful. REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. Operation: Repair Selected model: SM-G550T1 Software version: 27.3 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G550T1 Android version: 6.0.1 Product code: SM2G550TZKATMK Phone version: G550T1UVU1APF1 PDA version: G550T1UVU1APF1 CSC version: G550T1TMK1APF1 CSC country code: USA CSC sales code: TMK HW version: REV0.4 Phone SN: RV8H81BFS3T Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20160825 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON308 Calculating... Ok HWID: 3B A1 93 6C 3C 57 E3 83 28 F9 18 52 A9 33 C3 CD Repairing... Ok Writing NV data... Ok Rebooting phone... Ok Repair done Done with Samsung Tool PRO v.27.3 Last edited by sudonim; 12-04-2016 at 20:40. |
12-05-2016, 11:44 | #5 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
of course you will have zero without patch cert. | |
12-05-2016, 17:04 | #6 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | wait for repair this bugs mr blang patch ok all ok but imei not change always imei 000000 Operation: Patch Certificate Selected model: SM-G550T Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-G550T Android version: 6.0.1 Product code: Phone version: G550TUVU1APF1 PDA version: G550TUVU1APF1 CSC version: G550TTMB1APF1 CSC country code: USA CSC sales code: TMB HW version: Phone SN: 00000000000 Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.3 |
12-05-2016, 19:09 | #7 (permalink) |
Member: 2235849 Status: Offline Thanks Meter: 4 | Patching cert does not write imei. It is still all zeroes. REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. Operation: Patch Certificate Selected model: SM-G550T1 Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-G550T1 Android version: 6.0.1 Product code: SM2G550TZKATMK Phone version: G550T1UVU1APF1 PDA version: G550T1UVU1APF1 CSC version: G550T1TMK1APF1 CSC country code: USA CSC sales code: TMK HW version: REV0.4 Phone SN: RV8H81BFS3T Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20160825 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.3 |
12-21-2016, 14:35 | #10 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Subotica Age: 54
Member: 60687 Status: Offline Thanks Meter: 32 | ....working ...but.... ...patch certificate cannot fix 3g/4g network problem after direct unlock!!!! |
The Following User Says Thank You to arnoldmasa For This Useful Post: |
