08-04-2017, 15:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Algéria
Member: 484595 Status: Offline Thanks Meter: 39 | g610f/s cant repair imei here is the log REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G610F Software version: 28.2 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: Phone version: G610FDDU1APJ6 PDA version: G610FDDU1AQE4 CSC version: G610FOJV1AQE3 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: R28HA3BSKAL Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-05-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (2) Done with Samsung Tool PRO v.28.2 |
08-05-2017, 01:09 | #2 (permalink) |
Freak Poster Join Date: Jul 2011 Location: in /dev/null/01110cod3r1100101
Member: 1613754 Status: Offline Sonork: 1623976 Thanks Meter: 115 | Bro, copy efs full folder from another g610f (first root), and paste into your phone, not reboot, and go to z3x. Repair IMEI, patch cert and enjoy. Z3x backup efs, and cert not working, and always security damaged. Just manual copy complete EFS folder in /efs and paste to damage phone, for copy efs folder use root explorer, file explorer... Sent from my iPhone using Tapatalk |
09-16-2017, 04:41 | #3 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: SUVA
Member: 1622774 Status: Offline Sonork: 34610 Thanks Meter: 37 | ANY1 TEST ?IS DONE ? I HAVE 1 G610Y ,after reapir fail ,now not working .no network Quote:
12-30-2017, 17:50 | #4 (permalink) | |
Freak Poster Join Date: Jan 2014 Location: india
Member: 2111064 Status: Offline Thanks Meter: 21 | Quote:
hi good idea, the only otpion left to save my phone, can u pls share a good efs folder from anybackups you have , i cant get hold of an efs backup folder! wbr | |
